Glued tires to rim guys........... #2665535
06/13/19 02:48 PM
06/13/19 02:48 PM
St. Paul , Mn.
tubtar Offline OP
tubtar  Offline OP
St. Paul , Mn.
How are they for breaking down ?
I have a set of tires that I used Hi-Tack to stick them on the rims.
The tires ( 315 's ) were a C/H too wide for my car.
Now , I have rims with the right back spacing that have new tires glued to them.
Will they come apart without tearing up the tires / beads ?
Ideally , I can use the rims with 295's and save the tires for the next project.
I am getting very good at complicating simple projects. LOL
Re: Glued tires to rim guys........... [Re: tubtar] #2665566
06/13/19 04:14 PM
06/13/19 04:14 PM
baldwinsville new york
a493demon Offline
a493demon  Offline
You won't tear up the beads
Re: Glued tires to rim guys........... [Re: a493demon] #2665630
06/13/19 08:32 PM
06/13/19 08:32 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
My bias slicks are glued.Mark the tire at the wheel valve.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Glued tires to rim guys........... [Re: hemi-itis] #2665636
06/13/19 08:42 PM
06/13/19 08:42 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
They’ll be fine. I’ve been using HiTack on my last 2 sets. No issues whatsoever getting them off. You will want to clean the beads and rims with a citrus based cleaner after they’re off, before re-installing them.
Re: Glued tires to rim guys........... [Re: StealthWedge67] #2665648
06/13/19 09:12 PM
06/13/19 09:12 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
The biggest issue is that it's messy. However lacquer thinner cleans it up fine.
Doug
Re: Glued tires to rim guys........... [Re: dvw] #2665683
06/13/19 11:15 PM
06/13/19 11:15 PM
Doug
iagree scope up
Re: Glued tires to rim guys........... [Re: Cab_Burge] #2665745
06/14/19 09:12 AM
06/14/19 09:12 AM
St. Paul , Mn.
tubtar Offline OP
tubtar  Offline OP
St. Paul , Mn.
Thanks , Gentlemen.
I really appreciate it.
