Re: Safe Jacking Point
[Re: JFChallenger440]
#2663714
06/08/19 07:58 AM
06/08/19 07:58 AM
RapidRobert
JF there are no stupid questions, just rude answers & very few of them. You could jack it under the front K in the center which'd raise both front wheels up or at either of the rear subframes for a reat tire & in the front you could hit either subframe also instead of the K. A good plan is to just slightly loosen the lug nuts before you raise it
#2663901
06/09/19 01:42 AM
06/09/19 01:42 AM
Posts: 1,752 Phila
PhillyRag
Phila
Sorry may be a bit of a stupid question but where’s the safest point to Jack the rear up on a 70 Satellite ? It’s only to get 1 wheel off, thanks Place jack saddle (floor type jack) under axle center section: if that's the type jack you have. Raise until tires off ground. Springs will compress as you raise. Less total lifting involved. If jacked from a body point: spring(s) relax & need to raise more before tire clears ground.
[Re: PhillyRag]
#2664057
06/09/19 03:30 PM
06/09/19 03:30 PM
Posts: 1,456 oklahoma
forphorty
oklahoma
Sorry may be a bit of a stupid question but where’s the safest point to Jack the rear up on a 70 Satellite ? It’s only to get 1 wheel off, thanks Place jack saddle (floor type jack) under axle center section: if that's the type jack you have. Raise until tires off ground. Springs will compress as you raise. Less total lifting involved. If jacked from a body point: spring(s) relax & need to raise more before tire clears ground. On my 68 Sat, I have to jack the body up and let the rearend sag to get my wheels off due to big tires and 3 inch long wheel studs.
[Re: forphorty]
#2664223
06/10/19 12:45 AM
06/10/19 12:45 AM
Posts: 1,752 Phila
PhillyRag
Phila
Sorry may be a bit of a stupid question but where’s the safest point to Jack the rear up on a 70 Satellite ? It’s only to get 1 wheel off, thanks Place jack saddle (floor type jack) under axle center section: if that's the type jack you have. Raise until tires off ground. Springs will compress as you raise. Less total lifting involved. If jacked from a body point: spring(s) relax & need to raise more before tire clears ground. On my 68 Sat, I have to jack the body up and let the rearend sag to get my wheels off due to big tires and 3 inch long wheel studs. So you need to have springs sag so tires clear the wheel wells. As noted before: on the frame members in front of the spring hanger is a rigid part of most cars
