Smaller Oil Filter
#2660864
05/31/19 09:54 AM
05/31/19 09:54 AM
Posts: 1,927 Seaford, Va
Kindafast
Seaford, Va
Hey guy's before I go down to the auto parts and start searching do any of you know of a smaller , as in shorter and a little more narrow oil filter that will screw on the factory spot on a small block ? I bought some TTI big tube headers and the only way I can put the filter on is to loosen the headers so the oil filter will go by. Once it's on there the headers fit good but are a little close to the filter. Any help would be appreciated. I really don't want to try a 90* part or a remote filter setup. Thanks.
6.50 @105.26
Re: Smaller Oil Filter
[Re: Kindafast]
#2660870
05/31/19 10:18 AM
05/31/19 10:18 AM
Posts: 10,228 Colleyville
3hundred
Colleyville
Fram PH 16 or WIX 51085 is the small one that came on the magnum engines. Should fit your needs.
Robert
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
[Re: 3hundred]
#2660877
05/31/19 10:38 AM
05/31/19 10:38 AM
Kindafast
Seaford, Va
Thanks , I knew there were some smart people on here. !!
6.50 @105.26
[Re: moparx]
#2660933
05/31/19 12:43 PM
05/31/19 12:43 PM
Posts: 11,408 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
NAPA 1515 is the long filter. 1068 is a little shorter. 1085 is shorter yet. Add a 5 in front for the Wix number.
[Re: ZIPPY]
#2660980
05/31/19 03:24 PM
05/31/19 03:24 PM
Posts: 3,535 Canuckville
68Cbarge
Canuckville
Thanks for the info folks! I was wondering the same thing now that I am putting headers on my 318 73 wagon.
'68 Newport Custom Barge on a Budget!! BOAB 1973 Satellite WAGON! 318- 3 on the tree!! 2008 Chrysler 300c HEMI!
[Re: 68Cbarge]
#2661066
05/31/19 09:50 PM
05/31/19 09:50 PM
Kindafast
Seaford, Va
You guys are always great . Thanks for the info..
6.50 @105.26
[Re: Kindafast]
#2661107
06/01/19 07:13 AM
06/01/19 07:13 AM
Posts: 8,005 Tulsa OK
Bad340fish
Tulsa OK
I am sure this lines up with some of the info above but I use the Mopar filter that fits the Jeep 4.0 in my 97 Cherokee. It fits my big tube W2 TTI headers great. I think the Mopar number is like an M090 or something.
68 Barracuda Formula S 340 87 "Chrysler" Conquest
[Re: RapidRobert]
#2661134
06/01/19 09:09 AM
06/01/19 09:09 AM
Posts: 142 North America
kwikblownhemi
North America
On a side note I would not get a fram filter. I wouldn't use one on a bicycle. For twenty years I blew-off people who said they were junk. Then I witnessed failures of three Fram filters on three different vehicles.
[Re: kwikblownhemi]
#2661138
06/01/19 09:21 AM
06/01/19 09:21 AM
Kindafast
Seaford, Va
I have heard the same thing about Fram too. My engine builder told me long ago to not use them. Will check out the Mopar filter the next time I need to change the oil. I have a Purolator on there now but it most likely will not fit around the headers when I take it off. Maybe 1/16 too wide to fit between the header and the frame rail.
6.50 @105.26
[Re: RapidRobert]
#2661142
06/01/19 09:32 AM
06/01/19 09:32 AM
Posts: 19,239 north of coder
moparx
On a side note I would not get a fram filter. nor would i ! i mentioned that article because of the size reference. just cross the fram numbers over to wix, or your favorite brand of quality. there are several other size filters in the Wix brand that can come in handy, bigger and smaller. if you or anyone else can supply me with a "size" you may need that is different than the fram chart shows, [length, diameter, both] pm me and i will look up what is available in my Wix master catalog.
[Re: moparx]
#2661343
06/01/19 08:51 PM
06/01/19 08:51 PM
RapidRobert
i mentioned that article because of the size reference. just cross the fram numbers over to wix, or your favorite brand of quality. & very much appreciated
[Re: Kindafast]
#2661421
06/02/19 07:52 AM
06/02/19 07:52 AM
Bad340fish
Tulsa OK
The Mopar filters seem to work well. My understanding is that they are made by Purolator.
[Re: Bad340fish]
#2663142
06/06/19 05:17 PM
06/06/19 05:17 PM
Posts: 498 El Dorado Ca
65signet
El Dorado Ca
I use a Neon oil filter on my small block
1965 Plymouth Barracuda 273 M/SA 1970 Plymouth Duster 360/904 10.60s with J heads
