Fast Bleed Hydro Lifters?
#2663105
06/06/19 03:02 PM
06/06/19 03:02 PM
Porter67
I read alot about the rhoads type lifters that many brands make but what I dont see listed is how much duration on average do they bleed off at the lower rpms? Ive also read they dont like a hv oil pump, is this correct?
Any input would be helpful. Thanks.
Re: Fast Bleed Hydro Lifters?
[Re: Porter67]
#2663108
06/06/19 03:13 PM
06/06/19 03:13 PM
Posts: 14,491 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
All the noise of an old school loose lash solid......without the power or rpm capability.
[Re: fast68plymouth]
#2663113
06/06/19 03:30 PM
06/06/19 03:30 PM
Porter67
Thanks for the positive reply, but that still didnt give me a answer to my question. All the noise of an old school loose lash solid......without the power or rpm capability.
#2663139
06/06/19 05:12 PM
06/06/19 05:12 PM
Posts: 3,916 usa
lewtot184
usa
All the noise of an old school loose lash solid......without the power or rpm capability. mark engle told me that in every dyno test they ran with rhoads lifters they lost power.
[Re: Porter67]
#2663185
06/06/19 06:40 PM
06/06/19 06:40 PM
Posts: 1,565 tennessee
pushbutton
tennessee
Thanks for the positive reply, but that still didnt give me a answer to my question. All the noise of an old school loose lash solid......without the power or rpm capability. I used Crane Fast Bleed lifters in a low comp 383 with a 284-484 Purpleshaft and a 3:23 rear gear. They sure made it a lot more fun to drive around town,and was easier than a cam change. I wasn't looking for more power just trying to make up for a poor cam choice. Would I run them as a first choice---no,but they do have their place. I don't the Cranes' make as much noise as Rhodes.
[Re: Porter67]
#2663219
06/06/19 08:00 PM
06/06/19 08:00 PM
fast68plymouth
So. Burlington, Vt.
The other thing with that style of lifter is....... a lot of the added noise coming from the engine isn’t coming from where you think it is....... or for the reason(most) people think.
When the valve is closing, imagine where the point on the cam lobe the lifter is, when the engine is at low speeds and the lifter is partially collapsed....... and what the profile intensity is at that point, compared to the intensity at the designed closing point.
#2663235
06/06/19 08:31 PM
06/06/19 08:31 PM
Posts: 4,310 Prospect, PA
BSB67
Prospect, PA
....... and what the profile intensity is at that point, compared to the intensity at the designed closing point. Said differently, how much of the closing ramp is being used with a bled down lift making a hard landing for the valve. Plus rate of cam and spring pressure might have an impact on bleed down rate. All this nay saying aside, I have run Rhodes lifters and was happy with them.But I also like all of the racket coming from the valve train. Here is my recommendation. Zero lifter preload, 10/30 oil, standard volume pump but high pressure spring and use an old school slow rate cam.
