Re: Help me hook, please!!
[Re: Sammy]
#2662221
06/04/19 12:02 PM
06/04/19 12:02 PM
Posts: 14,539 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
If you still have them, I’d start by putting the old tires back on.
Cal Tracs didn’t make my car any quicker, but it was consistently good.
I ran normal rear springs(xhd) with mine, CE shocks on all corners, bottom hole, almost no preload. 1.51 60’ @3670lbs with a 383(typically 1.54-1.57). 9x30 Hoosier radial slicks, 20-21psi.
[Re: fast68plymouth]
#2662231
06/04/19 12:32 PM
06/04/19 12:32 PM
Posts: 223 California
70Drop
California
I ran normal rear springs(xhd) with mine, CE shocks on all corners, bottom hole, almost no preload. 1.51 60’ @3670lbs with a 383(typically 1.54-1.57). 9x30 Hoosier radial slicks, 20-21psi. Unfortunately, I sold the old tires or I'd definitely put them back on, at least as a test. Those bias tires liked low pressure too (7-8 psi). I've heard the Hoosier radials would work well for my application. Someone said they don't have as stiff a sidewall as the Mickeys, but I don't know if that's true or not.
[Re: 70Drop]
#2662277
06/04/19 02:49 PM
06/04/19 02:49 PM
fast68plymouth
So. Burlington, Vt.
Just to be clear, I was running radial drag slicks...... not any kind of dot drag radial.
What I ran previously were M/T 29.5x10.5 bias ply drag slicks..... at around 12-13lbs.
Those were with a different motor and no Cal Tracs(3400lb SS springs instead).
[Re: b1dartsport]
#2662408
06/04/19 09:59 PM
06/04/19 09:59 PM
70Drop
California
This guide was helpful to me That's really interesting
[Re: dvw]
#2662773
06/05/19 06:53 PM
06/05/19 06:53 PM
70Drop
California
Are you saying the Calvert shocks are -7 clicks from full tight or full loose? If they're-7 from full tight they're too loose. Guaranteed the front is too loose. As stated here the air pressure is way to low. Doug 7 clicks from full loose. I think they can go up to 9, which would be full tight, if I understand correctly
[Re: BradH]
#2662913
06/06/19 01:41 AM
06/06/19 01:41 AM
70Drop
California
I'm not patient enough to read what everyone else has stated above, but if you haven't figured it out already... radials can require a very different chassis setup than bias-plies.
Things I found critical getting my car to launch straight and stay hooked up: 1. Needed to lower my front ride height and cut down my upper control arm bumpers to get the 5+" free travel from static height; before that it would hook, then top out the front suspension and unload the rear tires 2. Only required about 1/3 turn additional pre-load on the passenger side to get it to go straight 3. My shocks are the OLD Ranchos that have 5 damping adjustments and mine are on 4 (one from stiffest)... and I'll probably need to upgrade to a decent DA in the future 4. Tire pressure... even 1/2 psi too low and my 275/60R15s would squish the sidewalls too much off the line; on skinny 8" rims they needed 17.5 psi to work OK and I've yet to try 'em out on the new 10" rims 5. Don't stage your car at such a high RPM that you're torqueing up the suspension; bias-plies can be a crutch for that, but radials need the pitch rotation to stick 6. Marginal tracks and radials don't get along well This is very useful info, Brad. I really appreciate it. Thanks to everyone
