76 D100 door buzzer thingy!
#2661303
06/01/19 06:56 PM
06/01/19 06:56 PM
Posts: 767 NW PA
V10nacuda
NW PA
I hope Im not being to technical sounding. Trying to wrap up a wiring nightmare on my kids newly-acquired D100 . I have never seen a dash harness wire harness and engine harness hacked so much with tape, wire nuts and some just Twisted wires. Got charging system straightened out and the heater motor working. All of a sudden I noticed intermittently it sounds like a door buzzer under the dash. I have never had one of these new or ever had a old truck like this that actually had a door buzzer that works. What exactly is that makes that buzzer go off? Is it just seat belts or key in ignition or combination thereof? Thanks V10
Re: 76 D100 door buzzer thingy!
[Re: V10nacuda]
#2661332
06/01/19 08:28 PM
06/01/19 08:28 PM
Posts: 15,713 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
My '79 W150 has a buzzer when the key is turned forward to on position before starting. If I remember correctly, it's about 15 seconds, then stops. I'd have to check that. Is your key always turned on when this intermittent buzzing is happening?
Facts are stubborn things.
[Re: larrymopar360]
#2661365
06/01/19 10:21 PM
06/01/19 10:21 PM
Posts: 7,828 east side of Ohio
basketcase
east side of Ohio
not sure when it started, but they started having buzzers for seatbelts, lights on (when the ignition was off)
1981 Dodge D150 360 auto
[Re: basketcase]
#2661396
06/02/19 12:32 AM
06/02/19 12:32 AM
Posts: 16,803 Between Houston & Galveston TX
SattyNoCar
I have my old Haynes manual that has a wiring diagram for '75-'78 models. It does show a relay and buzzer as well as a seat belt switch.
I don't have a scanner so I tried to take a few pics. On page 3 of 4, the relay and buzzer is top right. On page 4 of 4, the seat belt switch is top left. It's not clear where they are located, but hopefully this will help.
John
