Re: 727 experts ... a couple ??s
[Re: 469runner]
#2660704
05/30/19 06:36 PM
05/30/19 06:36 PM
Posts: 21,399 It's a dry heat
gtx6970
It's a dry heat
The primary difference between small and big block transmission is simply the case. The bolt pattern and shape are different for the engine families. Both small and big block could have 3 or 4 pinion planetaries, or 3 or 4 clutch drums depending on application. The short shaft transmissions were primarily used in trucks with 4 wheel drive or motor homes. Yep, you can gut either one and install everything inside the others case
[Re: radar]
#2660730
05/30/19 07:45 PM
05/30/19 07:45 PM
Posts: 1,682 Philadelphia
radar
Philadelphia
Your case was cast on: Day 8433 is Wednesday, August 29, 1984
I think the other #s are federally mandated abbreviated vin to discourage chop shops.
Man it feels good to be able to give back some trans knowledge- John Kunkel, Transman, moparax, and some other folks have been helping me out bigtime. Seems a good built trans costs about $300 if you do it yourself- $1500 to buy, and a super dooper race trans is about 2k ish to build and a gazillion dollars to buy. Plus with all the rumors about Total Crap Inside who knows if you can trust anybody these days...
[Re: Stanton]
#2660917
05/31/19 12:17 PM
05/31/19 12:17 PM
Posts: 25,747 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Can you tell anything from this vin# - year, model, etc ?? PK4329482 8433 0373
PK= Plant Kokomo 4329482= A 727 from an '84-'85 318 or 360 truck with a two-piece driveshaft 8433= Build date Aug 29, 1984 so it's a 1985 model year trans 0373= Sequence number, the 373rd built that day. BTW, that's not a VIN, the VIN is located on a raised pad on the bellhousing. The pic below shows the difference in the SB and BB case.
