Aluminum radiators again
#2659427
05/26/19 06:43 PM
05/26/19 06:43 PM
Posts: 9,594 Rittman Ohio
fourgearsavoy
Rittman Ohio
Doing a cam swap on my Savoy and while I have the radiator out I was going to replace the 22" unit with a 26" core. I have read good reviews about the Speed Cooling radiator and there are many people on here that like the Champion radiator. The Champion uses 3 small rows while Speed Cooling claims there 2 large tubes are superior to the small 3 tubes which makes sense to me. I plan on adding a shroud too so that will also be a factor in my final choice. I don't mind some cutting and drilling minor fab work to make it fit as I will have to do some mods to my car to take the 26" rad where the 22" rad was. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
Re: Aluminum radiators again
[Re: fourgearsavoy]
#2659441
05/26/19 07:14 PM
05/26/19 07:14 PM
Posts: 19,845 Niles , Ohio
therocks
Its Lost
Its Lost
Niles , Ohio
Gus I run the Champion 22 I got off Ebay.Like 150 a few years ago.The 440 is built radical and never gets over 180 no matter how hot.I ran a stock 22 from a Cbody with stock shroud for like 15 years and ran under 190.It got busted when the jack slipped.was leary about the champion but in the 3 years or so Ive had it no problems.I did have to open up the mount holes a bit.But I thibk my front is bent a bit.Rocky
Chrysler Firepower
[Re: Frankenduster]
#2659481
05/26/19 09:00 PM
05/26/19 09:00 PM
Posts: 1,455 Bradenton, Fl 34203
Kilroy was here
Bradenton, Fl 34203
now have the ECP 2 row , works well Me too, I put one in my 70 Charger (408 small block), keeps it nice and cool. I live in Florida....and it's flipppen HOT out!
[Re: csk]
#2659609
05/27/19 11:13 AM
05/27/19 11:13 AM
Posts: 14,130 So Near, Yet So Far
topside
So Near, Yet So Far
Had a Champion 26" in the 512" Duster, in its stock 22" opening, and with a mech fan and a shroud, cooled fine (175 tops) with no problems. Have a Griffin 22" in my SB Duster drag car (half-filled block, 18" elec puller, no shroud), plenty adequate; it likes a coolant temp of 120-130 staging. Might see 160 or so on the return road. Zero leaks or problems with either radiator, and the Griffin's been in there since around 1996. Looking at that ECP site, the radiators look like pretty screamin' deals if you don't need the electric fan setup. My only reservation with alum radiators is the non-OEM look in an otherwise restored car, but for hot rods, no worries there.
[Re: topside]
#2659738
05/27/19 07:01 PM
05/27/19 07:01 PM
Posts: 2,880 Washington
madscientist
Washington
If you want a radiator that fits like it should, use the Cold Case radiator.
As always, a big 2 core radiator will out cool a 3 or 4 core radiator all day long.
[Re: topside]
#2659749
05/27/19 07:48 PM
05/27/19 07:48 PM
Posts: 2,821 middle Tennessee
mopower440
middle Tennessee
Had a Champion 26" in the 512" Duster, in its stock 22" opening, and with a mech fan and a shroud, cooled fine (175 tops) with no problems. Have a Griffin 22" in my SB Duster drag car (half-filled block, 18" elec puller, no shroud), plenty adequate; it likes a coolant temp of 120-130 staging. Might see 160 or so on the return road. Zero leaks or problems with either radiator, and the Griffin's been in there since around 1996. Looking at that ECP site, the radiators look like pretty screamin' deals if you don't need the electric fan setup. My only reservation with alum radiators is the non-OEM look in an otherwise restored car, but for hot rods, no worries there. How did you bolt the bigger 26" radiator in place of the 22"? Did you just drill new holes in the radiator support and use nuts and bolts through it or?
[Re: mopower440]
#2659755
05/27/19 08:03 PM
05/27/19 08:03 PM
fourgearsavoy
Rittman Ohio
Had a Champion 26" in the 512" Duster, in its stock 22" opening, and with a mech fan and a shroud, cooled fine (175 tops) with no problems. Have a Griffin 22" in my SB Duster drag car (half-filled block, 18" elec puller, no shroud), plenty adequate; it likes a coolant temp of 120-130 staging. Might see 160 or so on the return road. Zero leaks or problems with either radiator, and the Griffin's been in there since around 1996. Looking at that ECP site, the radiators look like pretty screamin' deals if you don't need the electric fan setup. My only reservation with alum radiators is the non-OEM look in an otherwise restored car, but for hot rods, no worries there. How did you bolt the bigger 26" radiator in place of the 22"? Did you just drill new holes in the radiator support and use nuts and bolts through it or? That's gonna be my plan but I may use nut-serts just for ease of assembly. Looks like I will be going with the ECP Speed Cool 22" it looks like the best looking radiator of the bunch around $200 that has a mounting flange for a factory type shroud. Thanks again guys for all the input  Seems like every tech article I read about cooling they all say 2 large tubes are the best option for my application. Gus
[Re: fourgearsavoy]
#2659777
05/27/19 09:05 PM
05/27/19 09:05 PM
mopower440
middle Tennessee
Had a Champion 26" in the 512" Duster, in its stock 22" opening, and with a mech fan and a shroud, cooled fine (175 tops) with no problems. Have a Griffin 22" in my SB Duster drag car (half-filled block, 18" elec puller, no shroud), plenty adequate; it likes a coolant temp of 120-130 staging. Might see 160 or so on the return road. Zero leaks or problems with either radiator, and the Griffin's been in there since around 1996. Looking at that ECP site, the radiators look like pretty screamin' deals if you don't need the electric fan setup. My only reservation with alum radiators is the non-OEM look in an otherwise restored car, but for hot rods, no worries there. How did you bolt the bigger 26" radiator in place of the 22"? Did you just drill new holes in the radiator support and use nuts and bolts through it or? That's gonna be my plan but I may use nut-serts just for ease of assembly. Looks like I will be going with the ECP Speed Cool 22" it looks like the best looking radiator of the bunch around $200 that has a mounting flange for a factory type shroud. Thanks again guys for all the input  Seems like every tech article I read about cooling they all say 2 large tubes are the best option for my application. Gus Thats the one im lookin at also! The ECP 22" with the 1" tubes. Im just wondering if it will be enough to cool my 440? The original brass 22" currently in it just wont do it when its above 90 degrees here. Its fine when its cooler but cant keep it down in the summer heat..
[Re: DusterKid]
#2660174
05/28/19 09:03 PM
05/28/19 09:03 PM
Posts: 12,081 Great Neck,LI,new york
hemi-itis
I have a $200 Afco radiator with a single Spal 16 inch fan.Nice nights it runs 175*,,hot nights it run up to 185 to 190*
HEMI-ITIS has no cure. My condition is fully BLOWN!!!
New best 60ft,, 1.42,1/8, 6.0 @117,, 9.38 @146.75 with 6 lbs boost @3700 lbs
[Re: JAMESDART]
#2660465
05/29/19 07:46 PM
05/29/19 07:46 PM
Posts: 1,101 NH
NHCharger
NH
I had Wizard Cooling build me a radiator for my Daytona clone. Have a mild 440 in the car, flexi fan and radiator shroud, 170º t-stat. Have not had a problem yet, was stuck in Friday morning traffic last year at Carlisle for 30 minutes with no issues. My friend who owns a radiator repair shop checked out the radiator and said it was a nice unit.
My Dad always told me, when setting goals " avoid disappointment, aim low".
