Nord Lock Washers For Headers
#2659653
05/27/19 02:15 PM
05/27/19 02:15 PM
Posts: 1,272 Northern Calyfornua
Sxrxrnr
Northern Calyfornua
My TTI headers on aluminum head BB have a tendency to loosen, which requires occasional retightening. Am using studs. There are a number of locking technologies to help, I did an investigation of several and it appears this is as simple as any, more effective than others, and reasonable in cost. Amazon but not Summit sell. I did a search on our forum and found no references to their use, which is surprising. This U Tube video, comparing several options for locking was impressive. There are several such videos. https://m.youtube.com/watch?v=WPCfd4Zr6rEHas anyone on the forum used them, and if so,,,opinions? I am going to order up. Unfortunately sold in packs of 8, headers require 12.
Re: Nord Lock Washers For Headers
[Re: Sxrxrnr]
#2659694
05/27/19 05:25 PM
05/27/19 05:25 PM
Posts: 43,097 Bend,OR USA
Cab_Burge
Header gaskests compress under heat, correct? Same thing on bolts or studs when heated they grow in length, correct? My point is once you retighten them several times they should take a permanent set and stay tight, mine do As far as those locking washers on header flanges I would pass
[Re: Craig J]
#2659741
05/27/19 08:23 PM
05/27/19 08:23 PM
dartman366
Mt. Vernon, Ohio
I use them at work and are a dandy choice for locking things together but like said before that is not the problem gasket crush will require a couple of re-tightenings untill they take a set, once they do then you are as good as gold.
[Re: Sxrxrnr]
#2659830
05/28/19 03:17 AM
05/28/19 03:17 AM
Posts: 84 Norway
cudaerik
Norway
I use the Nordlock 3/8" washers on my engine in combination with remflex gaskets, hooker headers and Eddy heads. No header bolts coming loose and no leaks after five years.
1970 Plymouth Cuda, 512cid on 230 400 block, 5 speed manual.(TKO 600) 1970 Dodge Charger 500, 446cid, 5speed manual.(TKO 600) 1969 Plymouth Roadrunner, 383cid, 5speed manual (Tremec TKX)
[Re: cudaerik]
#2659981
05/28/19 12:44 PM
05/28/19 12:44 PM
Sxrxrnr
Northern Calyfornua
I use the Nordlock 3/8" washers on my engine in combination with remflex gaskets, hooker headers and Eddy heads. No header bolts coming loose and no leaks after five years. Having both remflex gaskets and nord locks(how much thicker are nord locks verses standard lock washer?), were standard length header bolts(or studs) long enough to get a adequate bite into head threads? Having aluminum heads, this could be an issue so as not to strip out threads. I would guess that upon initial installation a secondary torquing of bolts is still required after a few heating/cooling cycles.
[Re: rickraw]
#2660017
05/28/19 01:47 PM
05/28/19 01:47 PM
Posts: 403 Colorado front range
BcudaChris
Get some remflex gaskets. My bolts never loosened up with them. X2 Using the small head header bolts that came with my super comps.
[Re: Sxrxrnr]
#2660231
05/29/19 08:14 AM
05/29/19 08:14 AM
Posts: 84 Norway
cudaerik
Norway
I'm using 1" ARP bolts with the Nordlock washers and the Remflex gaskets.
