2nd generation rear valance panels: AMD fit 68-70 Charger #2659598
05/27/19 11:27 AM
05/27/19 11:27 AM
Houston, Tx
hemi68charger Offline OP
Houston, Tx
[i][/i]Hello All,
If I may, for those that have been-there-done-that, what are the issues one may encounter using the AMD rear valance product for their restoration? I'm comtemplating the purchase of an NOS unit, that isn't cheap, versus an AMD unit that is much cheaper, but I run into issues of labor associated with sheetmetal tweeking...
Thanks...
Troy
Troy
Houston Mopar Connection Club
Re: 2nd generation rear valance panels: AMD fit [Re: hemi68charger] #2659635
05/27/19 01:36 PM
05/27/19 01:36 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Charger valance I assume.
IMO the section where it rolls up and behind the rear bumper , the edges aren't near as sharp as an original. Some may never catch it. but once you see the difference it sticks out like a sore thumb to me
So to me it would depend on
A - how much more the nos one is.. Me personally value it at about double the repop, maybe even a little more
and B , how much accuracy means to you and you alone
Re: 2nd generation rear valance panels: AMD fit 68-70 Charger [Re: hemi68charger] #2659756
05/27/19 09:06 PM
05/27/19 09:06 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Originally Posted by hemi68charger
[i][/i]Hello All,
Thanks...
Troy
The 2nd gen Charger rear valance and corners have always been an issue with the aftermarket pcs...I did my Charger about 15 yrs ago, I used an NOS valance center and corner repros from Charger Specialties...I had zero fit issues, and neither pcs required any surgery, surprisingly the CS end pieces were extremely accurate
I know the AMD rear valance has been retooled, but it stil has issues with the shape and matching up to factory/NOS corners...the current AMD repro corners on the market have shape/angle issues as well, they can all work, it's just a matter of how much effort you want to put into it....
Mike
Re: 2nd generation rear valance panels: AMD fit 68-70 Charger [Re: DAYCLONA] #2661297
06/01/19 06:42 PM
06/01/19 06:42 PM
RI Deep in the rust belt
chargervert Offline
chargervert  Offline
Troy,there is an NOS rear valence pan in the B body parts for sale section,here on Moparts right now. That car is worthy of NOS parts when they are available.
70 Charger R/T SE 472 Hemi 70 Charger R/T convertible 70 Charger R/T V Code Sixpack 69 Charger R/T SE Sunroofcar 68 Charger 383 68 Charger 318 71 Charger R/T 70 Challenger convertible 71 Challenger convertible 71 Cuda 340 09 Challenger R/T Classic
Re: 2nd generation rear valance panels: AMD fit 68-70 Charger [Re: chargervert] #2664065
06/09/19 04:02 PM
06/09/19 04:02 PM
Houston, Tx
Houston, Tx
Hey Pete..
Believe it got sold before I pulled the trigger..
Troy
