Alternative to Using a ThermoQuad #2659476
05/26/19 09:52 PM
05/26/19 09:52 PM
Fargo ND
moparphilll Offline OP
Fargo ND
The Question:
What are the options OTHER THAN using a ThermoQuad Carb on my 340 to get the SAME height so my Shaker Bubble does not rub on Hood. I used a Base plate under a ederbrock performer carb and it raised the bubble to high. Do the make a replacement carb for the 71 thermoquad?
Re: Alternative to Using a ThermoQuad [Re: moparphilll] #2659498
05/26/19 11:00 PM
05/26/19 11:00 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Originally Posted by moparphilll
The Question:
Personally I'd make the TQ "work"...but if your seeking a "newer" alternative, there's the Demon
Re: Alternative to Using a ThermoQuad [Re: DAYCLONA] #2659506
05/26/19 11:53 PM
05/26/19 11:53 PM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
X2 on the TQ find someone to rebuild it.
Re: Alternative to Using a ThermoQuad [Re: moparphilll] #2659508
05/26/19 11:57 PM
05/26/19 11:57 PM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
holley
there was a holley replacment for the thermoquad they turn up now and then .
think i got one layin around somewhere .
Re: Alternative to Using a ThermoQuad [Re: DAYCLONA] #2659541
05/27/19 08:14 AM
05/27/19 08:14 AM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
The Question:
Yes this. If the Demon here will work your not only getting a brand new carb but an improved version of the Thermoquad. The Demon incorporates the best attributes of the Thermoquad the Quadrajet and the AFB with some additional improvements. Gentleman who designed it worked for Carter back in the 60s and 70s.
Keep old mopars alive.
Re: Alternative to Using a ThermoQuad [Re: 2boltmain] #2659544
05/27/19 08:22 AM
05/27/19 08:22 AM
^^^ sounds like a good plan assuming the "height" ain't a problem.
Re: Alternative to Using a ThermoQuad [Re: RapidRobert] #2659550
05/27/19 09:07 AM
05/27/19 09:07 AM
Mequon, WI
gzig5 Offline
gzig5  Offline
Mequon, WI
The main fitment problem I've heard about with the Street Demon carb is that a drop base air cleaner can hit the choke body. Folks either go with a flat lower pan or modify it for clearance.
The Street Demon is supposed to work very well out of the box. I was very close to buying one but fell into a good sale on an Edelbrock AVS2.
Re: Alternative to Using a ThermoQuad [Re: gzig5] #2659580
05/27/19 10:40 AM
05/27/19 10:40 AM
moparx Online content
moparx  Online Content
if you have the room around the valve covers, "sometimes" a 15 or 16" circle track drop base will work for extra choke clearance.
it may need modification however.
beer
Re: Alternative to Using a ThermoQuad [Re: gzig5] #2659585
05/27/19 10:45 AM
05/27/19 10:45 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Dimensions of the Demon Carb, courtesy of Speedway motors.
Relevant height: This carburetor is 3 1/4" tall from the bottom of the carburetor to the air cleaner surface., In the Q&A section.
Re: Alternative to Using a ThermoQuad [Re: Sniper] #2659590
05/27/19 10:54 AM
05/27/19 10:54 AM
good information to know. thanks for posting that ! up
beer
Re: Alternative to Using a ThermoQuad [Re: moparx] #2659612
05/27/19 12:20 PM
05/27/19 12:20 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
Best street carb I ever had was a T-quad that Demonsizzler went through for me.
Haven't seen a post from him in years, though.
App was a 406" SB Duster street car with A/C; started quickly after sitting, ran clean, perfect throttle response, 17MPG.
That was 2002-2004.
Worst POS carb I've ever had was a Race Demon 850DP, so I'm leery of the brand even though the one posted is a different animal.
Re: Alternative to Using a ThermoQuad [Re: topside] #2659629
05/27/19 01:24 PM
05/27/19 01:24 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
The Q should be .... why do you feel the Plastic Fantastic should be replaced ?
Re: Alternative to Using a ThermoQuad [Re: dOc !] #2659765
05/27/19 09:21 PM
05/27/19 09:21 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I had several different carbs on my 50 Dodge 4x4. It seems even the best one had to be messed with every year (I live where we have cold winters and hot summers, and the truck was driven year around. The best fix I ever made was installing electronic fuel injection.
That truck had the last carb on anything short of the mower at my house. Gene
Re: Alternative to Using a ThermoQuad [Re: moparx] #2659793
05/27/19 11:21 PM
05/27/19 11:21 PM
Fargo ND
Fargo ND
shaker base
Re: Alternative to Using a ThermoQuad [Re: moparphilll] #2659817
05/28/19 12:51 AM
05/28/19 12:51 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Holley did make a replacement carb with small primaries and big secondaries for the Quadrajet which I believe would also work as a Thermoquad replacement. Don't know if its still made though. I also agree the Thermoquad is a good carb if you know what your doing with it as they work great when done right.
I believe Mopar Muscle tested the Demon Thermoquad replacement they make about a year or so ago in the mag and it worked good. I have heard that Demon carb shown in this thread is a good working carb. Ron
Re: Alternative to Using a ThermoQuad [Re: moparphilll] #2659882
05/28/19 09:14 AM
05/28/19 09:14 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
The Thermoquad was a pretty good carb in it's day, but they were not without their problems. And as with any 50 year old carb, they were designed to run on a very different fuel than they would see today. So, any Thermoquad would need a bit of work.
The Street Demon was designed by an former Carter engineer, which is why it is similar to the Thermoquad. But it has a number of design features that set it apart from any other mild street oriented carb out there including the Thermoquad.
Go with the Street Demon. As mentioned, the only issue that might be encountered is the choke housing.
Master, again and still
Re: Alternative to Using a ThermoQuad [Re: DaveRS23] #2660000
05/28/19 01:07 PM
05/28/19 01:07 PM
Shoreline, Washington
72roadrunnergtx Offline
I have some recent experience trying to get a Street Demon 750 to run well on one of my Mopars. The following is my observation/opinions. The motor is a mild build 400, cold Edlebrock performer intake and E-street heads. Out of the box it was jetted pretty close for this combo but accelerator pump didn’t seem to be working correctly. Wound up having to open it up, found small gaps in lip of the acc pump the lip seal and a tear in the Holley umbrella style check valve. After replacing those parts the pump worked better but still needed some larger nozzle tuning to resolve some slight residual hesitation.
No trouble height wise as a Thermoquad replacement but required extensive throttle lever modifications to retain the original throttle cable, throttle pressure linkage components, and correct overall geometry. The Mopar throttle pin adaptor designed for the Street Demon and installed on the “universal” throttle lever on the Street Demon, was useless in avoiding the extensive mods. Plumbing for bowl vent and charcoal canister purge are not present, as with most universal aftermarket carbs.
Could never get the choke tuned correctly for decent cold start & run. The factory dual snorkel air cleaner had no issues with the choke housing. The documentation that came with Street Demon refers to possible interference with the choke linkage near the air horn and factory style air cleaners. There is nothing the locate, or center, the lower air cleaner other than the air cleaner stud. I could see where the air cleaner could shift out of place and contact the linage.
Another irritating issue was the “goggle” valve, secondary throttle blade, binding in its bore requiring excessive throttle pressure to overcome periodically, especially on first use after warm-up. Tried to reseat the throttle blade on its shaft to correct, helped a little but never resolved the issue completely.
Overall tolerances of the various components are not anything close to the Thermoquad, when in good shape, or new Holleys, ended up going back to the best Thermoquad I have. While a bit complex by comparison, with parts that are hard to come by now, a correctly tuned Thermoquad, in good shape, is hard to beat for performance and all-around drivability.
Holley still does make a spread bore replacement but it’s a 650 CFM vacuum secondary GM replacement design with a universal throttle lever. Ran one of those too, good drivability overall, just not same full throttle punch IMHO. The Mopar specific models are now long out of production.
BTW, I have the Street Demon 750 and all the extra tuning parts for it currently are on E-bay should there be someone here who would care to take it on. Priced well below what I have in it.
Street Demon 750
1972 Road Runner GTX 440 6bbl 5-speed
[img]http://72rrgtx.com/carpics/bucket/DSC06730r-1.jpg[/img]
Re: Alternative to Using a ThermoQuad [Re: moparphilll] #2660269
05/29/19 10:46 AM
05/29/19 10:46 AM
3
340clone Offline
340clone  Offline
I also have a '71 340 shaker set up. I eliminated the Thermoquad by going with a '70 factory cast iron intake, so I could use an AVS.
Re: Alternative to Using a ThermoQuad [Re: 340clone] #2660278
05/29/19 11:17 AM
05/29/19 11:17 AM
Should be noted too that the Street Demon is not really a Thermoquad replacement as it is a square bore configuration. It likely will not bolt directly on an OE cast iron spread bore manifold, just like the Edelbrock carbs, requires the use of a square bore to spread bore adaptor, that would mean additional height.
Re: Alternative to Using a ThermoQuad [Re: 72roadrunnergtx] #2660293
05/29/19 11:53 AM
05/29/19 11:53 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
I have run many an Edelbrock carb on a spreadbore manifold with no adapter. Just a thick carb to manifold gasket is sufficient.
