Re: Alternative to Using a ThermoQuad [Re: Sniper] #2660391
05/29/19 04:50 PM
05/29/19 04:50 PM
Scranton, PA
Montclaire Offline
Montclaire  Offline
Scranton, PA
I know on the factory 340 intakes with the double keyhole arrangement the speed demon will not fit without a spacer. It will fit on an older edelbrock performer (not air gap) though. I don’t know how much that will effect height for you. I think interference with the choke well was the issue on the factory piece.
Re: Alternative to Using a ThermoQuad [Re: 72roadrunnergtx] #2660441
05/29/19 07:39 PM
05/29/19 07:39 PM
Benton, IL.
DaveRS23 Offline
Master of nothing...
DaveRS23  Offline
Benton, IL.
The Street Demon has both bolt patterns, square and spread bore. Which is why it has the weird (I'ld call it a 3 barrel) secondaries so that it will fit both types of intakes. It is possible that there could be some interference on come parts of some manifolds. I haven't ran into any yet, but it's possible. But it wouldn't be a big deal to trim some metal if there were interference.
Master, again and still
Re: Alternative to Using a ThermoQuad [Re: Montclaire] #2660452
05/29/19 08:16 PM
05/29/19 08:16 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
That may be, all my LA 4bbl intakes are either very late model without a choke well to speak of (late 80's) or aftermarket.
Re: Alternative to Using a ThermoQuad [Re: Sniper] #2660479
05/29/19 09:38 PM
05/29/19 09:38 PM
Alberta
440_Offroader Offline
Alberta
Another thing to note on the street demon with the accelerator pump. I had a bad dead spot when hitting the pedal. Tried bigger nozzles and increasing pump stroke, but not much improvement. I found the air cleaner base was pushing down on it, limiting the stroke. I found this when I went for a quick drive without the air cleaner. I do have an aftermarket air cleaner though.
Re: Alternative to Using a ThermoQuad [Re: moparphilll] #2662284
06/04/19 03:34 PM
06/04/19 03:34 PM
Windsor, ON, Canada
Diplomat360 Offline
Diplomat360  Offline
Windsor, ON, Canada
For what it's worth: I run the 9800 series (aftermarket with electric choke) version on my 360 motor...very tunable, but as others have stated you really need to know the carb and a good parts selection helps.
Re: Alternative to Using a ThermoQuad [Re: Diplomat360] #2662293
06/04/19 04:13 PM
06/04/19 04:13 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
For what it's worth, I know you are looking for alternative to a TQ, but why not get one done by Scott Smith (Harm's Automotive) . . . .it will look the business and work ! . . . probably for same $$$$ that you would spend on getting another carb . . .
Just my 2cents worth . . .
Good luck with it . . .
Cheers,
Mark
