Coated steel oil pump gear Update #2659413
05/26/19 06:39 PM
05/26/19 06:39 PM
central il.
second 70 Offline OP
central il.
Worked on the car today and here are a couple of pictures of the crane gear I put in three years ago on a used solid roller cam and HV melling pump. No wear except where I had to use needle nose to remove it. Cam looked great too.
Mike
Re: Coated steel oil pump gear [Re: second 70] #2659423
05/26/19 07:32 PM
05/26/19 07:32 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Same experience here. I have over 5700 street miles and hundreds of dragstrip passes on mine. I pulled it this Spring to manually prime the pump and it and the hydraulic roller cam gear looked like the day I put them in there.
'63 Dodge 330
11.19 @ 121 mph
Re: Coated steel oil pump gear [Re: GY3] #2659442
05/26/19 08:19 PM
05/26/19 08:19 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
What make are these ??
Re: Coated steel oil pump gear [Re: Stanton] #2659450
05/26/19 08:40 PM
05/26/19 08:40 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Crane
'63 Dodge 330
11.19 @ 121 mph
Re: Coated steel oil pump gear [Re: second 70] #2659479
05/26/19 09:58 PM
05/26/19 09:58 PM
Thanks, that is good to know up bow
Re: Coated steel oil pump gear [Re: Cab_Burge] #2659501
05/26/19 11:25 PM
05/26/19 11:25 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
That is very good info, thanks for posting it. I have a crane gear but I was afraid to put it in because I thought it is too much of an unknown to run on drag week, where it could fail in the middle of nowhere. Now I have the confidence to install it. Thanks again
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Coated steel oil pump gear [Re: second 70] #2659527
05/27/19 06:41 AM
05/27/19 06:41 AM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Gear looks great. Good info. Seems like much better option than bronze gear.
Re: Coated steel oil pump gear [Re: sgcuda] #2659588
05/27/19 10:51 AM
05/27/19 10:51 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
My bronze gear is 15 years old and the are showing their age.Good to hear all this as now I also will install one bow
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Coated steel oil pump gear [Re: second 70] #2659592
05/27/19 11:09 AM
05/27/19 11:09 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Thanks for the update!!
Re: Coated steel oil pump gear [Re: fast68plymouth] #2659619
05/27/19 12:45 PM
05/27/19 12:45 PM
Canada
RobR Offline
RobR  Offline
Canada
How much spring pressure ? something like 350/750 type of spring..
Re: Coated steel oil pump gear [Re: RobR] #2659632
05/27/19 01:29 PM
05/27/19 01:29 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
HV oil pump or standard volume? I put one in my hemi with the HV pump, it has only 5 minutes of run time on it since I built it 8 years ago...
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Coated steel oil pump gear [Re: second 70] #2659868
05/28/19 08:30 AM
05/28/19 08:30 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Thank you, going to have to give that a try.
Rich H.
Esse Quam Videri
Re: Coated steel oil pump gear [Re: ZIPPY] #2659885
05/28/19 09:18 AM
05/28/19 09:18 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Why do the Mopar ones cost 30% more than all the others ?!?!?!?
Re: Coated steel oil pump gear [Re: second 70] #2659888
05/28/19 09:23 AM
05/28/19 09:23 AM
an8sec70cuda Offline
I think I'll definitely be getting one of these the next time I need one!
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Coated steel oil pump gear [Re: second 70] #2659942
05/28/19 11:34 AM
05/28/19 11:34 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I put that gear and hardened hex-end shaft in my RB when I changed the cam. Got it from Hughes. Remember, they expressly state on the instructions to only use it with a new cam. I guess the operating dynamics are much like a ring and pinion set. Keep them together once run.
Also, use a distributor shaft collar to limit how much the hardened gear can climb the cam gear during operation, which can dramatically effect the contact pattern between the cam gear and driven gear.
Re: Coated steel oil pump gear [Re: Stanton] #2659997
05/28/19 01:05 PM
05/28/19 01:05 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
90% less demand?
50% more material required?
"It's a Mopar thing"?
shruggy
Re: Coated steel oil pump gear [Re: jbc426] #2660002
05/28/19 01:08 PM
05/28/19 01:08 PM
BradH Offline
BradH  Offline
Originally Posted by jbc426
... they expressly state on the instructions to only use it with a new cam.
That's direct from Crane, who also states not to use it w/ high-volume or high-pressure oil pumps, IIRC.
I am curious how long a cam used w/ a bronze gear might still be OK to convert to one of these treated gears, considering the wear "should" be on the bronze gear up to that point.
Re: Coated steel oil pump gear [Re: BradH] #2660284
05/29/19 11:41 AM
05/29/19 11:41 AM
central il.
central il.
The cam was around 10 years old it was a Melling high volume oil pump. I don't know spring pressure for sure but should be close to 200/450#. This is the bronze gear that I removed. I'm no expert but I couldn't see how a bronze gear could hurt the cam? The biggest exception I heard was it could hurt the coated gear if there was a burr or any of the bronze stuck on the cam surface.
Re: Coated steel oil pump gear [Re: Stanton] #2660435
05/29/19 07:14 PM
05/29/19 07:14 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Why would you even consider buying anything from Mopar Performance?!
They quit supporting their "heritage performance cars" a long time ago. flame
'63 Dodge 330
11.19 @ 121 mph
Re: Coated steel oil pump gear [Re: GY3] #2660446
05/29/19 07:48 PM
05/29/19 07:48 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Quote
Where did you see the words "Mopar Performance" ?!?!?
If you go on Summit's or Jeg's sites you will see that the "Mopar" gears cost close to 30% more than the Ford or Chevy. I don't know what MP sells them for.
