Coated steel oil pump gear Update
#2659413
05/26/19 06:39 PM
05/26/19 06:39 PM
Posts: 1,696 central il.
second 70
central il.
Worked on the car today and here are a couple of pictures of the crane gear I put in three years ago on a used solid roller cam and HV melling pump. No wear except where I had to use needle nose to remove it. Cam looked great too.
Mike
Re: Coated steel oil pump gear
[Re: second 70]
#2659423
05/26/19 07:32 PM
05/26/19 07:32 PM
Posts: 4,663 Wichita
GY3
Wichita
Same experience here. I have over 5700 street miles and hundreds of dragstrip passes on mine. I pulled it this Spring to manually prime the pump and it and the hydraulic roller cam gear looked like the day I put them in there.
[Re: Cab_Burge]
#2659501
05/26/19 11:25 PM
05/26/19 11:25 PM
Posts: 7,477 Minnesota
Hemi_Joel
Minnesota
That is very good info, thanks for posting it. I have a crane gear but I was afraid to put it in because I thought it is too much of an unknown to run on drag week, where it could fail in the middle of nowhere. Now I have the confidence to install it. Thanks again
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: RobR]
#2659632
05/27/19 01:29 PM
05/27/19 01:29 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
HV oil pump or standard volume? I put one in my hemi with the HV pump, it has only 5 minutes of run time on it since I built it 8 years ago...
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: second 70]
#2659868
05/28/19 08:30 AM
05/28/19 08:30 AM
Posts: 17,838 S.E. Michigan
ZIPPY
S.E. Michigan
Thank you, going to have to give that a try.
Rich H.
Esse Quam Videri
[Re: second 70]
#2659888
05/28/19 09:23 AM
05/28/19 09:23 AM
Posts: 13,351 Marion, South Carolina [><]
an8sec70cuda
I think I'll definitely be getting one of these the next time I need one!
[Re: second 70]
#2659942
05/28/19 11:34 AM
05/28/19 11:34 AM
Posts: 3,277 West Coast, USA
jbc426
West Coast, USA
I put that gear and hardened hex-end shaft in my RB when I changed the cam. Got it from Hughes. Remember, they expressly state on the instructions to only use it with a new cam. I guess the operating dynamics are much like a ring and pinion set. Keep them together once run.
Also, use a distributor shaft collar to limit how much the hardened gear can climb the cam gear during operation, which can dramatically effect the contact pattern between the cam gear and driven gear.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: Stanton]
#2659997
05/28/19 01:05 PM
05/28/19 01:05 PM
BradH
Why do the Mopar ones cost 30% more than all the others ?!?!?!? 90% less demand? 50% more material required? "It's a Mopar thing"?
[Re: jbc426]
#2660002
05/28/19 01:08 PM
05/28/19 01:08 PM
BradH
... they expressly state on the instructions to only use it with a new cam. That's direct from Crane, who also states not to use it w/ high-volume or high-pressure oil pumps, IIRC. I am curious how long a cam used w/ a bronze gear might still be OK to convert to one of these treated gears, considering the wear "should" be on the bronze gear up to that point.
[Re: Stanton]
#2660435
05/29/19 07:14 PM
05/29/19 07:14 PM
GY3
Wichita
Why do the Mopar ones cost 30% more than all the others ?!?!?!? Why would you even consider buying anything from Mopar Performance?! They quit supporting their "heritage performance cars" a long time ago.
[Re: GY3]
#2660446
05/29/19 07:48 PM
05/29/19 07:48 PM
Posts: 8,853 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Originally Posted by Stanton Why do the Mopar ones cost 30% more than all the others ?!?!?!?
They quit supporting their "heritage performance cars" a long time ago. flame Where did you see the words "Mopar Performance" ?!?!? If you go on Summit's or Jeg's sites you will see that the "Mopar" gears cost close to 30% more than the Ford or Chevy. I don't know what MP sells them for.
