Good rear shock for a street strip a body
#2659411
05/26/19 06:34 PM
05/26/19 06:34 PM
Posts: 855 ontario canada kingston
aspenrt360
Hey there guy's as i continue to figure out what my wife's Demon needs i am about to change the rear shocks. i have a new set of SS springs in stock with everything i need to install them but the shocks. the car is a 72 340 demon with a slightly warmed over 360 727 with a 3500 rpm converter in it right now, the car is honestly 95% street driven but my wife likes to make a few passes each summer. the rear springs are bagged and it has an ancient set of air shocks that need to go, the front end is fully rebuilt and we are running 28'' drag radials. the car does not hook great right now but it tracks nice and straight and pulls hard down the track the 60ft sucks at 2.2-2.3 due to the wheel spin so i am looking to do some set up work to make it a bit better. the car runs 14.3-14.4 at 96-97 mph right now if i can get it to hook better i think it will be in the mid 13's which should be fine for my wife. i was looking at the Calvert shocks over at Mancini's those are the old Rancho's right? i want to be able to adjust them but i don't want to blow huge bucks for a mostly street driven car. any insights or personal experience would be great.
2013 Chrysler 300 touring 1974 Dodge Charger SE. 360-727-8.75-3.23 sure grip 1972 Dodge Dart Swinger 1995 Dodge Ram 1500 4x4
Re: Good rear shock for a street strip a body
[Re: radar]
#2659426
05/26/19 07:42 PM
05/26/19 07:42 PM
Posts: 4,669 Wichita
GY3
Wichita
I have the 3 way Competition Engineering adjustables up front and Rancho/Calvert 9 position adjustables out back. I've been 1.56 sixty foot so far but the prep has to be pretty good. They ride really rough on the street on full firm 9 compression setting but set them on 4 and the ride is fine. I make a massive amount of torque with my setup so it gets hard to hook in lesser conditions.
For a street/strip ride they acrually work pretty well but I would love to try some double adjustable Vikings.
[Re: GY3]
#2659438
05/26/19 08:03 PM
05/26/19 08:03 PM
aspenrt360
Thanks for the reply, those front shocks are they the kind you have to take out to adjust? seems i read about that somewhere? i think i like the idea of the Rancho/Calvert shocks in the back with the new springs. i am still not too sure about the fronts yet i may try the car with just the rear end stuff and see how that goes and if it still needs more i will get some front shocks. i left the sway bar on too as i had a charging issue that cut my night short but i will disconect it next time to help with transfer.
[Re: aspenrt360]
#2659452
05/26/19 08:44 PM
05/26/19 08:44 PM
GY3
Wichita
Thanks for the reply, those front shocks are they the kind you have to take out to adjust? seems i read about that somewhere? i think i like the idea of the Rancho/Calvert shocks in the back with the new springs. i am still not too sure about the fronts yet i may try the car with just the rear end stuff and see how that goes and if it still needs more i will get some front shocks. i left the sway bar on too as i had a charging issue that cut my night short but i will disconect it next time to help with transfer. Front shocks are a KEY component to making the car hook. I tried it with regular shocks and the front comes down too quickly and unloads the rear tires. Yes, you have to remove them to adjust, but I put them on 90/10 and never change the setting. They drive fine on the street with zero issues.
[Re: aspenrt360]
#2659483
05/26/19 10:07 PM
05/26/19 10:07 PM
Posts: 43,119 Bend,OR USA
Cab_Burge
[Re: parksr5]
#2659594
05/27/19 11:11 AM
05/27/19 11:11 AM
Posts: 19,342 north of coder
moparx
Honestly, with those times, I think some half way decent replacement shocks will work. I have a low 12 second car on street tires with 25+ year old Monroe shocks and have 1.7 sixty foot times. The car hooks hard at the track braking it up to around 1500rpm at launch. if the OP has SS springs, and running 13's, it may be possible to use the long monroes for a 3/4 ton truck. that way, the shock won't unload the rear due to topping out. these are not adjustable, just a suggestion that won't break the bank and may be what is needed on a mild application.
[Re: parksr5]
#2659675
05/27/19 03:56 PM
05/27/19 03:56 PM
aspenrt360
Yeah not planning on having it run those times in the future hence the upgrade... i have normal shocks on the front now and the bagged out springs and air shocks in the rear the plan is to install the super stock springs i already have here and get some ok shocks that are going to be long enough and work ok for what i have now. we have a couple of cars so i don't mind moving some parts around i just don't have shocks yet.
[Re: moparx]
#2659677
05/27/19 04:00 PM
05/27/19 04:00 PM
aspenrt360
Honestly, with those times, I think some half way decent replacement shocks will work. I have a low 12 second car on street tires with 25+ year old Monroe shocks and have 1.7 sixty foot times. The car hooks hard at the track braking it up to around 1500rpm at launch. if the OP has SS springs, and running 13's, it may be possible to use the long monroes for a 3/4 ton truck. that way, the shock won't unload the rear due to topping out. these are not adjustable, just a suggestion that won't break the bank and may be what is needed on a mild application. Thanks for the reply moparx i thought about c body or truck shocks too if i can't swing some caltrac / ranchos that will probably be the road i take. if i can get it to hook with a consistent 1.8 or 1.7 i would be really happy it would get the car into the 13's no problem. i have a couple of upgrades in the works for the engine once we get the chassis closer.
[Re: Cab_Burge]
#2659740
05/27/19 08:21 PM
05/27/19 08:21 PM
Posts: 11,708 Portage,michigan
B3422W5
Portage,michigan
Had super stock springs on a 3350 pound Duster. Not minitubbed. Ran CE 3 ways all around. Car ran 9.80’s and was ultra consistent anywhere.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: aspenrt360]
#2659887
05/28/19 09:22 AM
05/28/19 09:22 AM
Posts: 12,017 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Doesn't look like there is any consensus here. I have some 9 way Ranchos on the Cuda that work pretty good, but they have been on there for years. Are they still available as the Calverts?
Master, again and still
[Re: DaveRS23]
#2659889
05/28/19 09:30 AM
05/28/19 09:30 AM
Posts: 13,354 Marion, South Carolina [><]
an8sec70cuda
I used the Calvert/Rancho 9 way rear shocks from mid 11s to mid 9s w/ very good results. Had Lakewood 90/10s up front. All 90/10s aren't created equal! The Calvert 90/10s were too loose and my car would NOT hook at all w/ them. Once I started using nitrous and went into the 8s, I upgraded to Viking DA shocks.
[Re: 70sixpkrt]
#2660068
05/28/19 04:08 PM
05/28/19 04:08 PM
Posts: 2,814 Connecticut
FurryStump
Connecticut
I run kyb rear shocks with 1 inch overarched rear springs. If it has the power to spin the tire at the track, you don’t need anything fancy to get a sub 2 second 60 foot. I have run a 1.71 60’ with that rear suspension on f-70 14 redline tire. That being said I have installed qa1 R’s in the front and will be going to a double adjustable rear in the near future. Car is strip only kinda. Looking at qa1 double adjustable.
[Re: FurryStump]
#2660070
05/28/19 04:14 PM
05/28/19 04:14 PM
FurryStump
Connecticut
Also be careful any after market front shock doesn’t hit the bump stop bracket on the frame at full droop. Mine did so I had to clearance the bracket and I have seen a B body with the same issue.
