Efi pump setup to feed carb? My plan #2651682
05/03/19 06:51 PM
05/03/19 06:51 PM
gregsdart Offline OP
I plan on using a 255lph pump, a Moroso log type return regulator to reduce pressure to 15 psi. The return regulator i want to mount in back close to the tank. To reduce the pressure to 7 psi i have a holley blue regulator up by the carb. Anybody see any problems with this plan? I currently have a Carter street electric and 3/8 lines with no problems, just noisey ans MAYBE getting a little low on pressure in high gear. Dart, 408 cubes, 504 hp on the dyno. I am over hear because i am not getting any love elsewhere!
Re: Efi pump setup to feed carb? My plan [Re: gregsdart] #2651695
05/03/19 07:19 PM
05/03/19 07:19 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
A couple of things I would be concerned about would be heating up the fuel and the pump from being on bypass constantly to knock 60ish psi down to 15. The other would be loss of volume going through 2 regulators.
Is there such a thing as a stand alone electronic pump controller that would use pulse width modulation to control how much fuel is pumped? Simplifies the plumbing and gets rid of 2 mechanical regulators.
Kevin
Re: Efi pump setup to feed carb? My plan [Re: gregsdart] #2651726
05/03/19 08:47 PM
05/03/19 08:47 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
Hi Greg, I see what you are doing there. I think it will work fine and keep the pump happy. You might think about a nicer regulator up front
"Just a Bracket car dressed up like a streetcar"
Re: Efi pump setup to feed carb? My plan [Re: Twostick] #2651736
05/03/19 09:14 PM
05/03/19 09:14 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Kevin
Many generic pwm controllers out there, just make sure they'll handle 10-15v and ~20amps.
https://www.ebay.com/itm/12V-24V-Max-20A-PWM-DC-Motor-Stepless-Variable-Speed-Control-Controller-Switch/111936836128?epid=1462708855&hash=item1a0ff49220:g:REkAAOSwcUBYU0wW
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Efi pump setup to feed carb? My plan [Re: GoodysGotaCuda] #2651760
05/03/19 10:33 PM
05/03/19 10:33 PM
[quote=gregsdart]I plan on using a 255lph pump, a Moroso log type return regulator to reduce pressure to 15 psi. The return regulator i want to mount in back close to the tank. To reduce the pressure to 7 psi i have a holley blue regulator up by the carb. Anybody see any problems with this plan? I currently have a Carter street electric and 3/8 lines with no problems, just noisey ans MAYBE getting a little low on pressure in high gear. Dart, 408 cubes, 504 hp on the dyno. I am over hear because i am not getting any love elsewhere!
Kevin
The bypass regulator i have allows all the fuel to return to the tank through a relief valve, untill spring pressure is applied to the piston, raising pressure to what ever amount of spring pressure is applied. So the EFI pump will never be able to build pressure beyond what i set it at, about 15 psi.so it will move a lot of fuel to and from the tank, but at low pressure. Hopefully it won't build a lot of heat in the fuel.
Re: Efi pump setup to feed carb? My plan [Re: gregsdart] #2659387
05/26/19 04:50 PM
05/26/19 04:50 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
The way I have done it on multiple vehicles is an A1000 pump, a return system with one of their universal regulators...I typically use AN10 lines, but I have used AN08......Now I have used this with multiport and throttle body and with carbs....
If its carb or throttle body, I run from the bypass regulator up to the carb or throttle body with a dead head type system...Only the fuel from the regulator gets returned. I do not use any 90's if I can avoid them.
The A1000 works well from 6lbs all the way to 60lbs.....No issues with either. My Cuda is currently setup this way with a 1250 Dominator...
