power brake booster #2658916
05/24/19 10:31 PM
05/24/19 10:31 PM
middleburg,fl
barryv Offline OP
barryv  Offline OP
middleburg,fl
hi,
is there a difference between power brake drum booster and power front disc brake power booster. if there is a difference between them, how would braking be if using power drum booster with front power disc?.thanks
Re: power brake booster [Re: barryv] #2658967
05/25/19 06:44 AM
05/25/19 06:44 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
You might need to ask Cass ( DoctorDiff ) about that. I have a feeling that the actual booster is the same, if you are referring about an ebody. The difference may be in the way the rod on the master cly side of the booster is adjusted to length. The drum booster and disc master are different on a b body. The single diaphragm midland Ross is not as strong as the dual diaphragm Bendix used on the disc brake system.
Re: power brake booster [Re: fastmark] #2658974
05/25/19 07:28 AM
05/25/19 07:28 AM
VA
dragon slayer Offline
VA
Which car? If you look at service manual they usually were different especially on early cars. Several variations of boosters both midland, Bendix, single and dual. Also MC will be different Drum to Disc. Type of disc setup used can also effect the choice.
Re: power brake booster [Re: dragon slayer] #2658991
05/25/19 08:48 AM
05/25/19 08:48 AM
Andrewh Online content
Andrewh  Online Content
as said, it depends on what car. Some were the same, some were not.
those that were not, it basically does not give you enough assist.
Nothing wrong with being able to stop like normal, but you won't have the extra power needed for a panic stop where you could lock up all 4 wheels if it were the correct booster.
Re: power brake booster [Re: Andrewh] #2659184
05/25/19 09:26 PM
05/25/19 09:26 PM
middleburg,fl
barryv Offline OP
barryv  Offline OP
middleburg,fl
hi, its a 1970 road runner power drum brakes. I converted it a while back to front power disc. I kept the power drum booster on car. thanks
Re: power brake booster [Re: barryv] #2659288
05/26/19 09:25 AM
05/26/19 09:25 AM
VA
VA
I believe you would have a single diaphragm boost for power drum. The 70 B body used a Bendix dual diaphragm booster for power disc. So you might not have the same brake force with the drum booster. Did you swap MC too?
Re: power brake booster [Re: barryv] #2659290
05/26/19 09:31 AM
05/26/19 09:31 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Originally Posted by barryv
hi,
Typically a disc setup used a dual diaphragm booster and a drum setup used a single diaphragm booster. Discs need more pressure due to the lack of servo action that a drum brake has. But like everything there are exceptions to this in the industry.
Re: power brake booster [Re: 6PakBee] #2659334
05/26/19 12:29 PM
05/26/19 12:29 PM
middleburg,fl
barryv Offline OP
barryv  Offline OP
middleburg,fl
hi,
I do have a power front disc master cylinder installed. I converted to disc brakes for the front. I never have liked the feel of the brake pedal. I just realized after all these years ,maybe having the power drum booster hooked up has been my issue.thanks for the replies
Re: power brake booster [Re: barryv] #2659356
05/26/19 02:59 PM
05/26/19 02:59 PM
NY
LTLBEE Offline
LTLBEE  Offline
NY
Whats wrong with the feel of the brake pedal? Too hard or too soft.
Re: power brake booster [Re: LTLBEE] #2659773
05/27/19 09:45 PM
05/27/19 09:45 PM
middleburg,fl
barryv Offline OP
barryv  Offline OP
middleburg,fl
hi,
brake pedal seems to have to much travel.and a little soft. I have changed everything over the years more than once and never liked the feel of the pedal.i ordered a repo power booster for disc. I may have wasted my money but I figured it cant hurt and mine is real old anyway.thanks
Re: power brake booster [Re: barryv] #2659845
05/28/19 07:21 AM
05/28/19 07:21 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
Is the booster you have now a small midland ross unit that has a band clamp that holds it together or the larger bendix unit that crimped together? The midland ross unit is not strong enough for disc brakes.
Re: power brake booster [Re: fastmark] #2660158
05/28/19 09:36 PM
05/28/19 09:36 PM
middleburg,fl
barryv Offline OP
barryv  Offline OP
middleburg,fl
hi,
its a Bendix booster. I had it replaced about 30 years ago when I still had 4 wheel power drum brakes.thanks
