Page 2 of 5 1 2 3 4 5
Re: Suggestions on what to do with my motor? - update [Re: markz528] #2665841
06/14/19 01:27 PM
06/14/19 01:27 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
You picked a great builder. With a 572 and a GOOD MC head 1000 should be a no brainer. 1050 is easily attainable with easy on valvetrain parts IMO. I am quite sure he will meet your expectations.
Re: Suggestions on what to do with my motor? - update [Re: markz528] #2665843
06/14/19 01:28 PM
06/14/19 01:28 PM
NC
440Jim Offline
440Jim  Offline
NC
Mark, I like your plan. B1MC and 572 go nicely together.
The 950 hp target is conservative, and you might make more.
From what I have seen, at this level two similar motors might make different power, 950 for one, and 1030 on another.
The little things ($$$) matter at that level, IMO.
Re: Suggestions on what to do with my motor? - update [Re: Al_Alguire] #2665847
06/14/19 01:44 PM
06/14/19 01:44 PM
Morrow, OH
markz528 Offline OP
markz528  Offline OP
Morrow, OH
And I am spoiled that he is 45 minutes from me..............
Re: Suggestions on what to do with my motor? - update [Re: markz528] #2665860
06/14/19 02:22 PM
06/14/19 02:22 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
Originally Posted by markz528
Originally Posted by n20mstr
MY 530 made 915 @ BES, and its a dedicated nitrous motor. IM SURE yours will make over 1000, not 950
So you DO know Tony! grin grin grin
Yes I know him...LOL and they think im crazy because I sleep in my truck in the parking lot after driving there..LOL
My motor is 530" has a cam with 119lsa, only has a 1050 carb on it and its 13.7 comp. It was Dyno'd with C23. So think about it, your build will be 42 more cubes,the correct fuel for NA, the correct NA carb, a "NA" cam....1,000+ is a no brainer. Plus my engine stops making power at 7300 because of headers and intake design. Dont forget B1 are 30+ year old technology and having an intake that old don't help. At this time I just cant afford the money to cut the intake up and doctor it up to look like its cast again...that's future plans.
Good luck on your build. its a great place to deal with, the only bad thing you can say about them is they take long. But then again its worth the wait ! ! !
IF you want more info on my build id be happy to share in PM.
....BAD A$$ STREET CAR.....
Re: Suggestions on what to do with my motor? - update [Re: n20mstr] #2712142
11/02/19 04:31 PM
11/02/19 04:31 PM
Morrow, OH
markz528 Offline OP
markz528  Offline OP
Morrow, OH
Well making progress. Dropped the engine block off yesterday.
The first ports are ported and they will be digitized for CNC porting of the rest of the ports. No pics of the new ports. The chambers are machined but will be redone as not all cleaned up. At 1 inch the intake flowed 470 cfm - of course that number is meaningless as we don't care about 1 inch lift. Intake is 2.400 inch.
Not real happy with the intake machining. Brodix told me that Indy has their fingers in the intake machining.......... But the rest of the stuff looks good! Very surprised how heavy the rockers are.
Re: Suggestions on what to do with my motor? - update [Re: markz528] #2712182
11/02/19 06:47 PM
11/02/19 06:47 PM
gregsdart Offline
gregsdart  Offline
I like the route you chose. I am betting on a 8.90 to 8.80 at 150 mph with the chassis and converter working well!
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
Re: Suggestions on what to do with my motor? - update [Re: gregsdart] #2712192
11/02/19 07:13 PM
11/02/19 07:13 PM
Morrow, OH
markz528 Offline OP
markz528  Offline OP
Morrow, OH
We are shooting for 8.80's. Tony Bischoff crossed out 1000 hp and penciled in 1100 hp. LOL!
Re: Suggestions on what to do with my motor? - update [Re: markz528] #2712194
11/02/19 07:14 PM
11/02/19 07:14 PM
New York
polyspheric Offline
polyspheric  Offline
New York
I don't understand that part. How many different port shapes are there?
Boffin Emeritus
Re: Suggestions on what to do with my motor? - update [Re: polyspheric] #2712236
11/02/19 09:34 PM
11/02/19 09:34 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I may be wrong but I think he is saying they ported one port and got it to where they were happy and now they are going cnc the rest of the ports after they digitize it.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Suggestions on what to do with my motor? - update [Re: markz528] #2712292
11/03/19 12:24 AM
11/03/19 12:24 AM
gregsdart Offline
gregsdart  Offline
Looking forward to a track report. If 1100 hp is made it ought to be faster than 8.80!
Re: Suggestions on what to do with my motor? - update [Re: pittsburghracer] #2712293
11/03/19 12:51 AM
11/03/19 12:51 AM
Morrow, OH
markz528 Offline OP
markz528  Offline OP
Morrow, OH
Correct - They hand ported an intake and an exhaust port and those ports will be digitized to do the rest of the ports.
A true 1000 hp should get me in the high 8.80's per my calculator in good weather. A little north of 1000 hp would suite me just fine. I do not believe that we will get to 1100 hp but who knows with Tony.
Re: Suggestions on what to do with my motor? - update [Re: markz528] #2712371
11/03/19 12:13 PM
11/03/19 12:13 PM
ohio
67mprfan Offline
67mprfan  Offline
ohio
I drop my block and rotating assembly to them on Wednesday
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Re: Suggestions on what to do with my motor? - update [Re: 67mprfan] #2712380
11/03/19 12:29 PM
11/03/19 12:29 PM
Morrow, OH
markz528 Offline OP
markz528  Offline OP
Morrow, OH
up up up
Re: Suggestions on what to do with my motor? - update [Re: markz528] #2712423
11/03/19 01:55 PM
11/03/19 01:55 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Although a Chevy, I have a customer who went 8.84 at 150+ a few weeks ago w/his 572 Chevelle at 3430 lbs on stock suspension and radials and pump gas w/a Thumper 1250, he went 8.80's-90's w/an 1150 I did.......Pettis combo.....
Re: Suggestions on what to do with my motor? - update [Re: markz528] #2712597
11/04/19 09:00 AM
11/04/19 09:00 AM
N
n20mstr Offline
n20mstr  Offline
N
im sure it will go over 1000 !
oh god that intake...lol
heavy as hell and not that good lol
Re: Suggestions on what to do with my motor? - update [Re: n20mstr] #2773670
05/11/20 08:29 PM
05/11/20 08:29 PM
Morrow, OH
markz528 Offline OP
markz528  Offline OP
Morrow, OH
Well motor is in assembly. Won't be long now.............
Re: Suggestions on what to do with my motor? - update [Re: markz528] #2773689
05/11/20 09:40 PM
05/11/20 09:40 PM
N
n20mstr Offline
n20mstr  Offline
N
Im waiting for the dyno session !
Re: Suggestions on what to do with my motor? - update [Re: n20mstr] #2773871
05/12/20 12:56 PM
05/12/20 12:56 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Well Id say 1000 is a no brainer. You are certainly in good hands with BES, one of the best. Flow numbers are typical for a really good MC head at 1"
Re: Suggestions on what to do with my motor? - update [Re: Al_Alguire] #2773999
05/12/20 09:25 PM
05/12/20 09:25 PM
SoCal
Brian Hafliger Offline
SoCal
Total output will depend highly on camshaft...but 1050 is very doable with a decent cam (not full kill). Love love the MC heads!!
Brian Hafliger
Re: Suggestions on what to do with my motor? - update [Re: markz528] #2774116
05/13/20 09:41 AM
05/13/20 09:41 AM
NC
440Jim Offline
440Jim  Offline
NC
Tony Bischoff (BES) will build the motor. It will be a B1 MC head, 572 CI with 15:1 compression with a new cam. Will be targeting 950 hp. If my et calculator is correct, should get me in the 9.0's in my heavy aerodynamic brick..............
Good to hear the engine is being assembled. What are the cam specs?
Do you have head flow numbers at other lifts (0.700", 0.800")?
I look forward to the dyno numbers.
