Re: Can you get decent oil pressure with 0.013" Brg Clearance?
[Re: markz528]
#2658270
05/23/19 01:34 AM
05/23/19 01:34 AM
Posts: 43,097 Bend,OR USA
Cab_Burge
I made a similar mistake on my old 1955 Dodge D500 17 ft. flat bed, it had set for a long time before I bought it and I drove it for several 150 mile trips into the San Bernardino Mnts. from Joshua Tree,CA, The 254 C.I. straight flat head six it would have real low oil pressure when hot and idling, I tried changing the rod bearings thinking the motor was stock and put stock size rod bearing in it, it had a .010/.010 crank in it It knocked like crazy as soon as I started it up, luckily it didn't spin a rod bearing idling in my drive way so I took the old rod bearings to someone who knew a little more than I did back then and got a set of .010 rod bearing and did that job again with a lot better results Live and learn
[Re: markz528]
#2658444
05/23/19 03:33 PM
05/23/19 03:33 PM
Posts: 13,351 Marion, South Carolina [><]
an8sec70cuda
Wow! Surprised it wasn't more noisy!
Reminds me when a friend tore down his SBC for a rebuild. It was in a pro street style jeep wrangler w/ a blower on it. Ran mid 6s in the 1/8. It had .030" over pistons in a .060" over block. He had bought it years prior as a complete long block.
[Re: an8sec70cuda]
#2658449
05/23/19 03:44 PM
05/23/19 03:44 PM
Posts: 9,815 MI, usa
dvw
MI, usa
My son bought a 340 Duster. Ran great, pretty much stock ,13.30's. Sold the motor and the guy who bought it took it apart. .010" under crank with std main bearings. Doug
[Re: dvw]
#2658511
05/23/19 06:33 PM
05/23/19 06:33 PM
Posts: 20,158 Park Forest, IL
slantzilla
Park Forest, IL
Buddy of mine put std bearings on a .030" under crank in a 360. It didn't have much oil pressure when it warmed up.
[Re: markz528]
#2658513
05/23/19 06:36 PM
05/23/19 06:36 PM
Posts: 17,838 S.E. Michigan
ZIPPY
S.E. Michigan
SMH. The things people get away with.
Rich H.
Esse Quam Videri
[Re: markz528]
#2658535
05/23/19 08:16 PM
05/23/19 08:16 PM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
The first engine I built by myself was a 383 for a 71 RR I had at the time, this would've been around 81 or so. The crank was bad so I got one from my cousin and took it along with the block to the machine shop. They were supposed to polish, mic and order the correct bearings for it. After it was all done I picked up my parts and after a good cleaning put it together. At the time I didn't own any mics so I just screwed it together without even using plasti gauge. The engine started right up and had pretty good oil pressure, but when it warmed up it started knocking. The knock wasn't in the front or the back, it was everywhere, plus the oil pressure had dropped way down. So I pulled the engine out and apart to find the crank was .010/.010" and they gave me standard bearings. My Dad had done business for years with the machine shop and they were good about taking care of their mistake. They polished, miced and got the correct bearings for another crank, plus furnished me with another complete set of Fel-Pro gaskets. After that little experience I stepped up to plasti gauge. lol
[Re: ZIPPY]
#2658549
05/23/19 08:58 PM
05/23/19 08:58 PM
Posts: 11,497 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
SMH. The things people get away with. Anything I could say would just make everyone mad.
