Eagle 5.7, single S366, 720 whp 840 wtq #2657590
05/21/19 02:38 PM
05/21/19 02:38 PM
ghinmi Offline OP
ghinmi  Offline OP
Finally got a chance to lay the hammer down on the dyno with the baby turbo. 2009+ 5.7 hemi with drop in forged pistons/rods. 80 lb injectors, dual Walbro 255s, Holley HP EFI, Bullseye Street Billet S366. With the gate slammed shut it made 17 psi peak until it choked out and tapered down to 12 by the end of the pull. Normally makes peak power at 5500 at lower boost but only 4600 this way, severely turbo limited. Pretty surprised, didn't expect 700 whp this easy. It could make more if I pulled some fuel but I was thrilled with 720.
The little budget 5.7 keeps on surprising me.
1975 Jeep Cherokee compound turbo 5.7 Hemi/6 speed AutoX/Drag/Street.
9.97 @ 140 slicks, 10.74 in autox trim
Re: Eagle 5.7, single S366, 720 whp 840 wtq [Re: ghinmi] #2657607
05/21/19 03:25 PM
05/21/19 03:25 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
awesome work! that little 5.7 is screaming. apparently you don't need much on these hemis to make hellcat power.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: Eagle 5.7, single S366, 720 whp 840 wtq [Re: ghinmi] #2657718
05/21/19 07:38 PM
05/21/19 07:38 PM
southwest Alabama
challenger73400 Offline
southwest Alabama
That thing is sweet! Thanks for sharing!
Re: Eagle 5.7, single S366, 720 whp 840 wtq [Re: challenger73400] #2657759
05/21/19 09:04 PM
05/21/19 09:04 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
What valve springs did you go with?
Ray
Re: Eagle 5.7, single S366, 720 whp 840 wtq [Re: sixpackgut] #2657787
05/21/19 10:38 PM
05/21/19 10:38 PM
ghinmi Offline OP
ghinmi  Offline OP
Ray
You know my legendary cheapness. It's still on the original ones. One of these days I'll bite the bullet and upgrade.
Re: Eagle 5.7, single S366, 720 whp 840 wtq [Re: ghinmi] #2657991
05/22/19 12:56 PM
05/22/19 12:56 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
this just proves that boost is king. stuff the engine full of air and fuel and watch it work.
2574 Elliott Dr
Troy MI 48083
www.sdconcepts.com
www.bcrproducts.com
Re: Eagle 5.7, single S366, 720 whp 840 wtq [Re: Jerry] #2658230
05/22/19 10:20 PM
05/22/19 10:20 PM
IL
furious70 Offline
furious70  Offline
IL
I started tracking the prices of 6.1's and 6.4's as a basis for my Coronet eventually, maybe I don't need that additional upfront expense smile
Already got a 76mm 1.23AR T6 baby dump truck turbo for it.
How much power did you make before the drop in slugs?
And before re-gapping the rings?
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Eagle 5.7, single S366, 720 whp 840 wtq [Re: furious70] #2658421
05/23/19 02:41 PM
05/23/19 02:41 PM
ghinmi Offline OP
ghinmi  Offline OP
I'd have to go back and look but I'm pretty sure it did 580 whp and 654 ft-lbs with the stock untouched bottom end. Went in the 10s at 4000 lbs with a clutch. I never hurt it, just upgraded so that I didn't have to worry about it.
Re: Eagle 5.7, single S366, 720 whp 840 wtq [Re: ghinmi] #2658918
05/24/19 10:49 PM
05/24/19 10:49 PM
racine,wi
70gtx1 Offline
70gtx1  Offline
racine,wi
Wow, so impressive!! Been following your threads because I've been impressed with your ride. Seeing what you did, It really is convincing myself when the big block in my GTX needs to be gone through, to go a route like what you did. Big power and drivability, so nice!
Re: Eagle 5.7, single S366, 720 whp 840 wtq [Re: 70gtx1] #2659213
05/25/19 11:24 PM
05/25/19 11:24 PM
Australia
L4staero Offline
L4staero  Offline
Australia
Is it still running the std 5.7 cam?
Re: Eagle 5.7, single S366, 720 whp 840 wtq [Re: L4staero] #2660380
05/29/19 03:50 PM
05/29/19 03:50 PM
ghinmi Offline OP
ghinmi  Offline OP
It's still got the OEM cam/springs.
Re: Eagle 5.7, single S366, 720 whp 840 wtq [Re: ghinmi] #2661362
06/01/19 10:13 PM
06/01/19 10:13 PM
IL
furious70 Offline
furious70  Offline
IL
What are you doing for crankcase ventilation?
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Eagle 5.7, single S366, 720 whp 840 wtq [Re: furious70] #2668729
06/22/19 02:17 PM
06/22/19 02:17 PM
ghinmi Offline OP
ghinmi  Offline OP
I have a sealed catch can inline with the pcv loop and a vented catch can on the crankcase vent.
Re: Eagle 5.7, single S366, 720 whp 840 wtq [Re: ghinmi] #2668877
06/22/19 11:24 PM
06/22/19 11:24 PM
IL
furious70 Offline
furious70  Offline
IL
Any close ups is that stuff?
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Eagle 5.7, single S366, 720 whp 840 wtq [Re: furious70] #2669072
06/23/19 04:23 PM
06/23/19 04:23 PM
ghinmi Offline OP
ghinmi  Offline OP
You can see the cans in this picture. Silver one is the vented one that runs to the crankcase vent on the driver's side of the 5.7 intake. Black one is the sealed one that goes inline with the PCV loop.
Re: Eagle 5.7, single S366, 720 whp 840 wtq [Re: ghinmi] #2669185
06/23/19 10:48 PM
06/23/19 10:48 PM
IL
furious70 Offline
furious70  Offline
IL
what did you do for manifolds? Do you have a thread anywhere showing the build of the turbo stuff?
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Eagle 5.7, single S366, 720 whp 840 wtq [Re: furious70] #2671034
06/28/19 10:02 AM
06/28/19 10:02 AM
ghinmi Offline OP
ghinmi  Offline OP
On my previous hemi Cherokee I built customer headers for the turbo system. This one is using LS up and forward headers with adapter plates. They fit my application but not most others.
Unfortunately I don't really have a build thread on this one but I do have one for my red one before this. There's a little detail on the blue one at the end. http://www.ifsja.org/forums/vb/showthread.php?t=127321
Re: Eagle 5.7, single S366, 720 whp 840 wtq [Re: ghinmi] #2671252
06/28/19 06:08 PM
06/28/19 06:08 PM
IL
furious70 Offline
furious70  Offline
IL
interesting, I think I'm going to be looking for all the width I can save in a car so even adding that adapter plate in there might be too much. Someone at PRI saw some company with some Gen III turbo manifolds but I haven't been able to track anything done.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Eagle 5.7, single S366, 720 whp 840 wtq [Re: ghinmi] #2672792
07/01/19 10:19 PM
07/01/19 10:19 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
Are you doing drag week again this year?
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: Eagle 5.7, single S366, 720 whp 840 wtq [Re: Silver70] #2673448
07/03/19 12:31 AM
07/03/19 12:31 AM
ghinmi Offline OP
ghinmi  Offline OP
No, not able to make Drag Week again this year. My big trip was going to be the FM3 Cars and Cones week but I ended up moving clear across the country and couldn't make that either. Hoping to do some fun stuff again soon.
