Smallest mini Starter availabke #2657246
05/20/19 03:03 PM
05/20/19 03:03 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Who makes a mini starter smaller than the regular mini startes that you get from your local auto parts store .
I'm having clearance issues with my custom headers. Old one broke and it came out in 2 pieces but new one doesnt fit,
Cant get the transmission out without a starter installed.
Re: Smallest mini Starter availabke [Re: Sammy] #2657258
05/20/19 04:07 PM
05/20/19 04:07 PM
Cab_Burge Online work
Cab_Burge  Online Work
Which motor and car are you needing help on?
Re: Smallest mini Starter availabke [Re: Sammy] #2657277
05/20/19 05:16 PM
05/20/19 05:16 PM
AndyF Offline
AndyF  Offline
The RobbMc starter might work for you. It isn't smaller but you can rotate the housing. https://www.robbmcperformance.com/products/mopar_starter.html
Re: Smallest mini Starter availabke [Re: AndyF] #2657282
05/20/19 06:05 PM
05/20/19 06:05 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
I was looking at the Meziere TS306 which is smaller in diameter than the TS106 but it is longer.
Custom headers weren't built to remove the starter, unfortunately.
The MP mini starter is too thick in diameter to fit between the header tubes and block.
Re: Smallest mini Starter availabke [Re: AndyF] #2657283
05/20/19 06:07 PM
05/20/19 06:07 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Have you ever used one of these before?
They look like a quality built product.
Re: Smallest mini Starter availabke [Re: Sammy] #2657288
05/20/19 06:22 PM
05/20/19 06:22 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
Powermaster XS is pretty small and worked well on my old heap.
Re: Smallest mini Starter availabke [Re: Bigcube] #2657304
05/20/19 07:32 PM
05/20/19 07:32 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
That looks real nice but is it smaller than a Mopar Performance mini Starter?
I have very little room to slip it in .
Re: Smallest mini Starter availabke [Re: Sammy] #2657310
05/20/19 07:43 PM
05/20/19 07:43 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
I had both, seems like it was smaller than the Chrysler one. I even took off the heat shield on the Mopar one for extra room. Not a great pic but it's hidden in there....
