Electricians, strange home electrical issue? #2656925
05/19/19 04:23 PM
05/19/19 04:23 PM
Crook County, ILL
Mastershake340 Offline OP
Crook County, ILL
I just noticed my hall light is blinking on and off rhythmically, with the switch off.
There are 3 different switches that will turn the light on. I tried each and the light turns on, but when you switch it off, it starts blinking on and off again.
I replaced the old light fixture with a new one 3 or 4 years ago and it’s been fine up until now. I’m pretty ignorant about electrical stuff.
Any ideas what would cause this?
Re: Electricians, strange home electrical issue? [Re: Mastershake340] #2656928
05/19/19 04:39 PM
05/19/19 04:39 PM
Crook County, ILL
Crook County, ILL
I found if I carefully put the stairway light switch in the middle position, the light is off and doesn’t blink.
I take that to mean that simply it’s just that switch has gone bad and needs replacement?
Re: Electricians, strange home electrical issue? [Re: Mastershake340] #2656929
05/19/19 04:40 PM
05/19/19 04:40 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
question #1 what else is powered by that same circuit ?
Until the issue is diagnosed I would not leave the circuit breaker on for extended periods beer
Re: Electricians, strange home electrical issue? [Re: Mastershake340] #2656932
05/19/19 04:43 PM
05/19/19 04:43 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
One could turn the breaker off, and then bypass or replace the suspected switch. popcorn
Re: Electricians, strange home electrical issue? [Re: TJP] #2656937
05/19/19 05:01 PM
05/19/19 05:01 PM
Crook County, ILL
Crook County, ILL
The upstairs lights are all on that circuit breaker. The west and east side wall outlets are on 2 other circuit breakers.
Re: Electricians, strange home electrical issue? [Re: Mastershake340] #2656947
05/19/19 05:43 PM
05/19/19 05:43 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Silly question #2 Are there any LED bulbs in the lights on that circuit ?
It may be just a bad switch but sounds a bit strange shruggy
Re: Electricians, strange home electrical issue? [Re: TJP] #2656959
05/19/19 06:05 PM
05/19/19 06:05 PM
Crook County, ILL
Crook County, ILL
In fact, the hall light burned out last month so I replaced the incandescent light bulb with an LED.
Re: Electricians, strange home electrical issue? [Re: Mastershake340] #2656967
05/19/19 06:27 PM
05/19/19 06:27 PM
Crook County, ILL
Crook County, ILL
I just replaced the light switch I suspected, but the light is still blinking. realmad
Re: Electricians, strange home electrical issue? [Re: Mastershake340] #2656972
05/19/19 06:49 PM
05/19/19 06:49 PM
Between Houston & Galveston TX
Satilite73 Online work
Satilite73  Online Work
Change the bulb. It can be another LED bulb, but change it out with a known good one.
I only use LED's and have had a couple of 'bad' bulbs. I have had where the light would flicker, but not a full 'on, off, on, off'.
The light strip over my bathroom sink takes 5 bulbs. I switched them all to LED when I moved in 9 months ago. A couple of months ago, one bulb started coming on slower than the rest. Still lights just as bright, but there's like a 1 or 2 second delay compared to the other bulbs. I tried that bulb in different sockets with the same result.
John
Imagine a '73 Satellite Wagon picture here. 😁
Re: Electricians, strange home electrical issue? [Re: Satilite73] #2656977
05/19/19 07:00 PM
05/19/19 07:00 PM
St.Louis,Mo.
70RR383 Offline
70RR383  Offline
St.Louis,Mo.
Is there a dimmer involved??If you introduced a new style led,or LED bulb,,,you need a new style dimmer compatible
with them
Re: Electricians, strange home electrical issue? [Re: 70RR383] #2656985
05/19/19 07:08 PM
05/19/19 07:08 PM
Crook County, ILL
Crook County, ILL
No dimmer. Just a standard ceiling fixture in the upstairs hall with 3 switches in various locations that turn it on and off.
I tried changing the LED out for a standard 75W incandescent from my stash. It doesn’t blink now with the switch off, and turns on when the switch is turned on.
So I guess it’s an issue with the LED bulb?
Oh well a $2.00 switch from Menards and 15 minutes swapping it out isn’t too bad compared to any throwing parts at trying to fix a car problem excercise I’ve done over the years! grin
Re: Electricians, strange home electrical issue? [Re: Mastershake340] #2656991
05/19/19 07:22 PM
05/19/19 07:22 PM
St.Louis,Mo.
70RR383 Offline
70RR383  Offline
St.Louis,Mo.
The LED was picking up some residual current from somewhere,not uncommon.
Re: Electricians, strange home electrical issue? [Re: 70RR383] #2656997
05/19/19 07:44 PM
05/19/19 07:44 PM
Once again, I'm talking to myself. Glad you figured it out.
eyes
John
Re: Electricians, strange home electrical issue? [Re: Satilite73] #2657005
05/19/19 08:10 PM
05/19/19 08:10 PM
Port Huron, Michigan
MI_Custumz Offline
MI_Custumz  Offline
My kitchen overhead lights flicker after turning them off sometimes. It's something to do with the fixture and adding LED to them. I could swap out a few parts to get them to not flicker, but I haven't gotten around to it yet.
Re: Electricians, strange home electrical issue? [Re: MI_Custumz] #2657013
05/19/19 08:31 PM
05/19/19 08:31 PM
Crook County, ILL
Crook County, ILL
I appreciate everyone’s input and advice on this issue! beer I hadn’t thought it might be something as simple as quirks with LED lightbulbs. I figured for sure it was issues with my houses 60 year old wiring or a bad switch.
I hoarded a bunch of incandescent lightbulbs away when they were phased out. I’ll be set for years to come!
Re: Electricians, strange home electrical issue? [Re: Mastershake340] #2657214
05/20/19 12:38 PM
05/20/19 12:38 PM
Posts: 4034 - Register...
5thAve Offline
5thAve  Offline
I think it's the circuitry in the LED bulbs that holds power a bit and does it. I have a nightlight in my trailer that looks like it has an LED bulb in it judging by the color of it and it'll be on even when there's no 120V power and no voltage at the plug.
Re: Electricians, strange home electrical issue? [Re: 5thAve] #2657263
05/20/19 04:19 PM
05/20/19 04:19 PM
State of Jefferson
hooziewhatsit Offline
State of Jefferson
I would be tempted to replace the other two switches as well.
If one switch isn't completely open, it can still pass some voltage/current, (enough for the LED to notice, but not the incandescent), while holding another switch half way may be enough to completely break the circuit.
Re: Electricians, strange home electrical issue? [Re: hooziewhatsit] #2657479
05/21/19 10:21 AM
05/21/19 10:21 AM
Illinois
SIX225 Offline
SIX225  Offline
Illinois
I have switches that light up when the fixture is off. With LEDs in the fixtures, some brands of LED lamps will flash due to the small amount of current through the light up switch.
Re: Electricians, strange home electrical issue? [Re: SIX225] #2659489
05/26/19 10:22 PM
05/26/19 10:22 PM
Millinocket, Maine
JonC Offline
JonC  Offline
Millinocket, Maine
I had the same problem, mine turned out to be a lighted switch. The switch would pass a small amount of power to the LED and when the capacitor in the LED got charged enough it would come on like a flash bulb every 10 seconds or so. If you have a lighted switch, take is out and try again.
11B40
Re: Electricians, strange home electrical issue? [Re: SIX225] #2659559
05/27/19 09:39 AM
05/27/19 09:39 AM
Millinocket, Maine
JonC Offline
JonC  Offline
Millinocket, Maine
Sorry Six, didn't read all the posts before I replied.
11B40
Electric window switch removal
by Transman. 06/26/19 09:14 PM
Hemi block identification
by MoonshineMattK. 06/26/19 08:57 PM
Welcome new member moparmania1971 !!
by Satilite73. 06/26/19 08:49 PM
If you like Sassy green, could be a deal
by TJP. 06/26/19 08:05 PM
VICTORY
by 6bblFLASH. 06/26/19 07:41 PM
Lost Info need help
by Dduster. 06/26/19 07:35 PM
Moparts Recent Posts
Superbird with a Mod Top
by Rhinodart. 06/26/19 09:54 PM
by Doc Fiberglass. 06/26/19 09:50 PM
Amp meter bypass help please
by 71charger. 06/26/19 09:47 PM
Heat riser - ditch it or keep it?
by ricomondo. 06/26/19 09:46 PM
by Transman. 06/26/19 09:44 PM
HELP! way too much timing!!!!
by fast68plymouth. 06/26/19 09:43 PM
