Re: 68 gtx trim question
[Re: 65pacecar]
#2656705
05/18/19 10:24 PM
05/18/19 10:24 PM
Posts: 21,474 N.E. OHIO, USA
A12
N.E. OHIO, USA
Satellite trim. The GTX was never offered with that trim unless some Dealer installed for the first owner Yep Satellite trim, had this Satellite for a while with that top trim and side trim also.....was a nice solid southwest (El Paso) no rust but a ding or two Had a great looking two tone gold and white interior with A/C Hopefully your friend's car has an original fender tag or broadcast sheet?
[Re: RUNCHARGER]
#2656864
05/19/19 01:07 PM
05/19/19 01:07 PM
Posts: 20,645 So Near, Yet So Far
topside
So Near, Yet So Far
Easiest check is the SO # on the rad support vs the fender tag, but if the upper yoke's been changed, that throws that off. Obviously look at the dash tag rivets, or see if the dash was swapped, see what the engine (if any - bellhousing flange, top front pad, block side pad)) & trans #s are. I can't imagine the factory built a '68 GTX with Satellite trim, or managed to install every GTX feature into a Satellite shell.
