68 gtx trim question #2656534
05/18/19 10:59 AM
05/18/19 10:59 AM
British Columbia
chrisf Offline OP
chrisf  Offline OP
British Columbia
friend just bought a 68 gtx (rs23l) i have not seen the car but he sent me this pic of the trim. anybody ever seen a gtx with this trim?
Re: 68 gtx trim question [Re: chrisf] #2656538
05/18/19 11:28 AM
05/18/19 11:28 AM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
No.
Sheldon
Re: 68 gtx trim question [Re: RUNCHARGER] #2656560
05/18/19 01:06 PM
05/18/19 01:06 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
iagree got more pics of the car? does the car have a fender tag? do the body numbers match the fender tag?
Re: 68 gtx trim question [Re: 6bblgt] #2656588
05/18/19 02:22 PM
05/18/19 02:22 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Satellite. He'd better take a good look at the tags & rivets...
Re: 68 gtx trim question [Re: topside] #2656656
05/18/19 06:23 PM
05/18/19 06:23 PM
KY
65pacecar Offline
65pacecar  Offline
KY
Satellite trim. The GTX was never offered with that trim unless some
Dealer installed for the first owner
Re: 68 gtx trim question [Re: 65pacecar] #2656705
05/18/19 10:24 PM
05/18/19 10:24 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Yep Satellite trim, had this Satellite for a while with that top trim and side trim also.....was a nice solid southwest (El Paso) no rust but a ding or two wink Had a great looking two tone gold and white interior with A/C up Hopefully your friend's car has an original fender tag or broadcast sheet?
Re: 68 gtx trim question [Re: A12] #2656737
05/19/19 01:53 AM
05/19/19 01:53 AM
British Columbia
chrisf Offline OP
chrisf  Offline OP
British Columbia
thanks guys. i said satellite as well and he said he checked it for numbers. s/o number in 68 not the full vin. on the body, correct? says fender s/o tag matches rad support and trunk stamp. he is new to mopars and has deep pockets so..............................how do they say? Caveat emptor ill look it over when he gets home.
Re: 68 gtx trim question [Re: chrisf] #2656840
05/19/19 11:44 AM
05/19/19 11:44 AM
RUNCHARGER Offline
RUNCHARGER  Offline
Not much in this "hobby" is real anymore anyhow.
Sheldon
Re: 68 gtx trim question [Re: RUNCHARGER] #2656864
05/19/19 01:07 PM
05/19/19 01:07 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Easiest check is the SO # on the rad support vs the fender tag, but if the upper yoke's been changed, that throws that off.
Obviously look at the dash tag rivets, or see if the dash was swapped, see what the engine (if any - bellhousing flange, top front pad, block side pad)) & trans #s are.
I can't imagine the factory built a '68 GTX with Satellite trim, or managed to install every GTX feature into a Satellite shell.
