Re: By-pass Valve on Roots Supercharger
[Re: earlymopar]
#2656487
05/18/19 08:41 AM
05/18/19 08:41 AM
Posts: 8,027 Tulsa OK
Bad340fish
Tulsa OK
I don't know that you can bypass a blower in a carb'd application. That bypassed air will have fuel in it.
68 Barracuda Formula S 340
[Re: earlymopar]
#2656758
05/19/19 08:24 AM
05/19/19 08:24 AM
Posts: 1,335 Oregon
earlymopar
For those of you not familiar, "the best kept secret in forced induction is the little known bypass valve that allows the supercharger to be extremely efficient in terms of economy and parasitic power loss. The bypass is operated by a vacuum actuator control unit that is normally closed. When vacuum is high (idle-cruising) the actuator opens the bypass valve, equalizing the vacuum pressure throughout the system. When boost is required (accelerating) the vacuum is decreased and the bypass valve instantly closes, causing pressure to increase into the cylinders. This vacuum condition virtually eliminates the normal parasitic power loss of a forced induction system."
I solved the issue that caused me to post this thread. I'm simply using the vacuum port in the manifold that was provided for power brakes. BTW, attached is the same Magnuson I have, shown here on a Chevy....
Thanks,
- EM
[Re: earlymopar]
#2656828
05/19/19 11:11 AM
05/19/19 11:11 AM
Posts: 14,498 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Apparently it works.......but my thoughts were that it would be a tuning nightmare for part throttle operation since your recirculating air that already has fuel in it.
With MPFI, the fuel is introduced into the system after any recirculating of inlet air has been done.
