What Will It Run? #2656425
05/17/19 10:51 PM
05/17/19 10:51 PM
Taxes & Virus's R-US, NY
Dragula Offline OP
Dragula  Offline OP
69 Dart, we figure weighs 2950 or so, with a basic mini tub with DR315's out back, skinnys up front, 440/512 with iron heads, 3.90 gears with a spool, untouched 950 4150 carb with Indy intake. 10.7:1 and .560 mechanical roller with like no duration shifting at 6K......Car has race buckets, but a full back seat and a roll bar. Suspension is SS leaf and pinion snubber...
I ran this car tonight in the street class for its first outing........So I already know the answer, but my guess was right on the money.....This is my old 512, but with cast iron super stock heads from back in the day....Everything on the car is old school.
Re: What Will It Run? [Re: Dragula] #2656434
05/17/19 11:26 PM
05/17/19 11:26 PM
Superfreak
Superfreak
9.50 ?????
Re: What Will It Run? [Re: Dragula] #2656440
05/17/19 11:42 PM
05/17/19 11:42 PM
Between 10.50 to 11.00 twocents
Re: What Will It Run? [Re: Cab_Burge] #2656441
05/17/19 11:46 PM
05/17/19 11:46 PM
baldwinsville new york
a493demon Offline
a493demon  Offline
11.30
Re: What Will It Run? [Re: Cab_Burge] #2656443
05/17/19 11:54 PM
05/17/19 11:54 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Well mine was lighter with more cam but mine was 60 cubic inches smaller (stock crank) with 906 heads and it went 9.82 in the 1980’s so how about a 10.10
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: What Will It Run? [Re: pittsburghracer] #2656451
05/18/19 12:18 AM
05/18/19 12:18 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
10.30's
Re: What Will It Run? [Re: CSK] #2656513
05/18/19 10:01 AM
05/18/19 10:01 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Wag......... 10.50’s
But...... I think John’s Duster from the 80’s looks great in that pic, and sounds like it was running real strong.
Weiand TR on it?
Re: What Will It Run? [Re: fast68plymouth] #2656525
05/18/19 10:34 AM
05/18/19 10:34 AM
PA.
"Little"John
"Little"John
PA.
Weiand TR on it?
Ya I went back and forth between a couple of different 4 barrel intakes and a 1050 dominator but the Weiand Tunnelram ran so nice I only had to touch the 750 holleys once or twice a year. 76 jets all Summer and 78 jets in the Fall air. I still have those 906 heads sitting on a shelf not far from those old school 750 lift roller cams.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: What Will It Run? [Re: pittsburghracer] #2656532
05/18/19 10:54 AM
05/18/19 10:54 AM
Dragula Offline OP
Dragula  Offline OP
We were there testing & tuning for the start of the anticipated "Street" class at Empire...and ran with the "Street" cars....A first for me. Even My Cuda, which is street legal, I run in the race car classes.....
Well, that old engine went a best of 9.70 in my Duster with Indy EZ1 heads and a car that weighed 2700 and a .680 cam.....We have been racing that damn engine since 2012...There are so many passes on it, its not even funny anymore.
So way less cam, 250lbs heavier, less heads, I figured a loss of 1second......Car went 10.72 last night at almost 126mph with mufflers and street tires! Car launched with a 1.50 60ft lifting the fronts up off the pavement...I never though the radials would hook, as I have never had a set that did....
Had a blast.....First run, I did a John Force burn out so bad, you couldn't see the new Challenger SRT in the other lane.....I know, your not supposed to do that, but the tires were old and I wanted some heat in them.
They were all in the lanes before hand talking BS with other street guys and that Challenger was a gorgeous car. I thought maybe its one of those that runs deep into the 11s or so, never seen it before and I was not sure what my car was going to do....When I treed him and left, he was so far back I was shocked...Would love to see the look on the guys face after the crusty Dart got to the finish like 3 seconds ahead of him....
Second run was against a Honda Acura with a bunch of Spanish speaking fellas talking $hit....And we out ran that little 16 second rev it to the moon time bomb...
Last run was against a fast Phord Mustang, and he got out on me and broke mid run and coasted to a stop.....Another 10.73 run but a little less 60ft with a 1.52....
I think we have a nice little street killer bracket car....
Re: What Will It Run? [Re: Dragula] #2656572
05/18/19 01:38 PM
05/18/19 01:38 PM
Wichita
GY3 Online content
GY3  Online Content
Wichita
My guess was going to be 10.80's so I was close!
'63 Dodge 330
11.19 @ 121 mph
Re: What Will It Run? [Re: GY3] #2656818
05/19/19 10:42 AM
05/19/19 10:42 AM
Dragula Offline OP
Dragula  Offline OP
The car is a beast considering how daily driver friendly it is....I now know where to set the tire pressure and launch, so we will see if we can back it up next outing or improve upon the 10.72....Last year at the very last TNT of the season, I had a chance to run it with slicks, no exhaust, and 4.56 gears and the best it did was 10.91....So the 10.72 was kinda a shock,,,Not to mention we pulled the big gears and put an exhaust on it and drag radials....And now it pulls the front wheels, what a blast!
Re: What Will It Run? [Re: Dragula] #2657020
05/19/19 08:52 PM
05/19/19 08:52 PM
ontario canada kingston
aspenrt360 Offline
aspenrt360  Offline
cool!
2013 Chrysler 300 touring 1974 Dodge Charger SE. 360-727-8.75-3.23 sure grip 1972 Dodge Dart Swinger 1995 Dodge Ram 1500 4x4
Re: What Will It Run? [Re: Dragula] #2657161
05/20/19 09:46 AM
05/20/19 09:46 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
That's a cool car, I like it!
Rich H.
Esse Quam Videri
Re: What Will It Run? [Re: ZIPPY] #2657162
05/20/19 09:52 AM
05/20/19 09:52 AM
Dragula Offline OP
Dragula  Offline OP
Goes for paint at the end of the season....whole different color...I am hoping to pull the engine first so we can detail it nicely before hand.
Re: What Will It Run? [Re: Dragula] #2657294
05/20/19 06:53 PM
05/20/19 06:53 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
I like it, brings back memories cool
Re: What Will It Run? [Re: Bigcube] #2657329
05/20/19 08:29 PM
05/20/19 08:29 PM
Dragula Offline OP
Dragula  Offline OP
Wow...they look like twins....
