Incorrect 70 E-body ignition switch tumbler and/or housing
#2656433
05/17/19 11:20 PM
05/17/19 11:20 PM
Posts: 8,827 Houston, Tx
hemi68charger
Houston, Tx
Operation "is this a proper 70 key cylinder"? This cylinder will not lock into place in the steering column housing. The detent you see there seems to be too big to go into the locking hole of the steering column housing.. Or, is the steering column housing incorrect? The hole of the housing is smaller than the extent on the key cylinder.
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
Re: Incorrect 70 E-body ignition switch tumbler and/or housing
[Re: PhillyRag]
#2656462
05/18/19 03:38 AM
05/18/19 03:38 AM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
Correct, the earliers cylinders is actually a 1 year only setup for 70s, pretty much like turning switches, althought these were extended up to first 71 half.
[Re: NachoRT74]
#2656494
05/18/19 09:00 AM
05/18/19 09:00 AM
hemi68charger
Houston, Tx
Great picture !!!! I have the one on the left, so maybe I can just drill out the hole in the housing to allow the detent pin to extend into the hole so it locks properly? I guess if my detent pin style won't lock, then my friend's car is a detent blade style. So either need to get that version of the cylinder or drill out the access hole to allow pictured-style detent pin to protrude into the hole and lock as needed.
