Re: 1980 w150 , /6 - can’t resolve fast idle
[Re: stumpy]
#2656423
05/17/19 10:39 PM
05/17/19 10:39 PM
Posts: 360 mississippi
lostdog
mississippi
Choke linkage adjusted correctly. It can keep the fast idle cam up. The choke linkage isn’t even connected. The actuating Rod is all jacked up and bent so I wouldn’t even know what it’s supposed to look like. Can you tell me how to correct it ?
[Re: lostdog]
#2750730
03/10/20 12:11 PM
03/10/20 12:11 PM
Posts: 14,610 Not2farfromNashville, TN
Rug_Trucker
How's the slop in the throttle shaft? The butterfly can hang up. Get vacuum leaks around the shaft too.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
