Floor Jack #2655637
05/15/19 08:46 AM
05/15/19 08:46 AM
Hunt Valley, Maryland
1fastrunner Offline OP
My son is looking for a floor jack for his personal use at home. Maximum lift would be important as he has a Ram 1500 and Jeep Wrangler. There are so many out there, just not sure where to look. Sears was always a go to, but not so sure anymore. Any advise and experiences would be greatly appreciated.
Re: Floor Jack [Re: 1fastrunner] #2655656
05/15/19 09:56 AM
05/15/19 09:56 AM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Check the reviews on the Harbor Freight jacks.
1970 Duster
Edelbrock headed 408
6.143@110.85 mph
9.73@135.05 mph shifting at 6700 RPM
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Floor Jack [Re: 1fastrunner] #2655661
05/15/19 10:25 AM
05/15/19 10:25 AM
Fragged State of Skuldruggery
srt Offline
srt  Offline
My trustworthy, old, Hein-Werner developed a leak in the middle of a project and with no rebuild parts available, I bought one on sale at Napa, thing has worked great.
It's their 2 t blue and yellow low profile. I se it on our ctd ram, one corner at a time often and going strong for over 6 yrs.
Re: Floor Jack [Re: srt] #2655674
05/15/19 10:56 AM
05/15/19 10:56 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I have the NAPA 3-1/2 ton that on the first pump it goes up to where you want to start jacking, the only thing I don't like is that the handle does not rotate 90 degrees, it only goes up 45 degrees! shruggy
JB Rhinehart, Realist
A-Body's RULE!
Re: Floor Jack [Re: Rhinodart] #2655680
05/15/19 11:25 AM
05/15/19 11:25 AM
srt Offline
srt  Offline
the 2 ton I have will go just past straight up and stay for storage against wall.
Re: Floor Jack [Re: srt] #2655704
05/15/19 12:50 PM
05/15/19 12:50 PM
North East USA
BIGGERED Offline
Reasonable Title
BIGGERED  Offline
Reasonable Title
North East USA
Surprised you could not find seals for an old Hein Werner jack. My two-1/2 ton from the forty's is my go to jack! The pump angle kind of sucks but the jack is more than 20 years older than me.
I know jack repair places are getting scarce but most of those have standard seals.
Thank you
Red
Re: Floor Jack [Re: 1fastrunner] #2655706
05/15/19 01:01 PM
05/15/19 01:01 PM
enfield, CT
ViperDave Offline
ViperDave  Offline
enfield, CT
I have 4 floor jacks.
1 is a 30 year old craftsman still works, but its not a high lift.
I have 2 sears professionals that are maybe 5 years old, both are junk, leak, and one has a broken weld.
I have a harbor freight one that is 10 years old (bought in a pinch) works great I plan to buy another one.
67 Dart GT Vert 273/904
72 Town & Country 440/727
90 D350 reg cab dually cummins
15 Scat Pack Challenger
Re: Floor Jack [Re: 1fastrunner] #2655711
05/15/19 01:17 PM
05/15/19 01:17 PM
Charlotte, NC
Orange_Crush Offline
Belieber!
Belieber!
Charlotte, NC
https://www.harborfreight.com/3-ton...or-jack-with-rapid-pump-green-64785.html
Goes up to 24 1/4 inches and the price is downright reasonable.
1970 Dodge Charger R/T Hemi Orange U-code 4-speed
1971 Jaguar E-Type Series 3 V-12 4-speed 2+2 Signal Red.
Re: Floor Jack [Re: Orange_Crush] #2655782
05/15/19 06:09 PM
05/15/19 06:09 PM
Posts: 4034 - Register...
5thAve Offline
5thAve  Offline
Look for the best deal and don't look back. If it leaks down or doesn't work right exchange it for another one. I've never had a cheap jack go bad under normal hobby type use, most of them even hold up with professional use.
Re: Floor Jack [Re: 5thAve] #2655797
05/15/19 06:45 PM
05/15/19 06:45 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
A freind I know owns a tire store that does nothing but tires PERIOD. He was buying 600.00 snap on jacks that were failing after 1.5 to 2 years. He happened to be in a harbor Freight store and the manager talked him into trying their (new at the time) Daytona jack with a promise of a full no questions asked refund.
I was there recently and he has about 8 of the Daytonas. He said they last about 3 years and he is more than happy with them, especially at the price. I will close in saying this guy should be a test depot for floor jacks as they get the cr-p used out of them. twocents
Re: Floor Jack [Re: TJP] #2655808
05/15/19 07:20 PM
05/15/19 07:20 PM
They have more than 1 Daytona and there's a $60 difference. Is the $200 jack that much better than the $140 one?
Re: Floor Jack [Re: 1fastrunner] #2655820
05/15/19 07:51 PM
05/15/19 07:51 PM
Freeport IL USA
P
poorboy Offline
poorboy  Offline
P
Freeport IL USA
After my made in the early 70s Craftsman jack showed signs of its age and abuse I got one of the Harbor Freight 3 ton jacks. Its been flawless the past 3-4 years. Think I bought it on sale for something like $79. Gene
Re: Floor Jack [Re: 1fastrunner] #2655848
05/15/19 08:40 PM
05/15/19 08:40 PM
Charlotte, NC
Belieber!
Belieber!
Charlotte, NC
The expensive one is a long reach low-profile jack.
I believe it has a higher lift than the cheaper jack. I may be wrong, about that though.
Re: Floor Jack [Re: 1fastrunner] #2655854
05/15/19 08:56 PM
05/15/19 08:56 PM
SoMd, USA
135sohc Offline
135sohc  Offline
SoMd, USA
I have the 'prior generation' I'll call it version of THIS ONE so no rapid pump fast lift stuff. I did sucker in and buy the extended warranty for like $12 at the time and collected on it once. The replacement has been going strong for like 5 years now. If it died tomorrow I would buy another one no question. HF's mfg got the release valving perfect, very controllable so it does not drop and slam to the ground like most jacks tend to do.
Drill a 1/2" hole through the top of the handle and put a 6" bolt & locknut on it to gain some control when cracking the valve open to lower it.
Re: Floor Jack [Re: 135sohc] #2655938
05/16/19 08:09 AM
05/16/19 08:09 AM
Perkiomenville PA
RWG75 Offline
RWG75  Offline
Perkiomenville PA
Scored this one cheap on craigs a few years back - almost never use my floor jack any more.
75 Charger SE - 440/4, cop suspension
76 Daytona - survivor
76 Daytona - tweaked
77 PW - macho clone, sno-commander, frankenram
79 RC - this was your fathers 4x4
79 LRE - More fun than it looks
Re: Floor Jack [Re: RWG75] #2655968
05/16/19 09:40 AM
05/16/19 09:40 AM
Charlotte, NC
Belieber!
Belieber!
Charlotte, NC
Use that thing on a new truck and then spend the next few hours trying to figure out how to fix the air dam. It'll probably work well on the rear though.
Re: Floor Jack [Re: Orange_Crush] #2655986
05/16/19 11:10 AM
05/16/19 11:10 AM
Perkiomenville PA
RWG75 Offline
RWG75  Offline
Perkiomenville PA
I'll just flip the saddles around and use the jack slots in the bumper grin
Re: Floor Jack [Re: TJP] #2655989
05/16/19 11:15 AM
05/16/19 11:15 AM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
I see a lot of independent shops who have a Youtube Channel use a jack from Harbor Freight. I have 2 both are great.
Keep old mopars alive.
Re: Floor Jack [Re: 2boltmain] #2656040
05/16/19 02:39 PM
05/16/19 02:39 PM
Northern OH
rapom Offline
rapom  Offline
Northern OH
I have a 3 ton Daytona that I got for 179, and the $79 low profile 3 ton hf jack. The Daytona one rolls real nice over the floor, lifts higher, and has a nice controlled release. The other one works nice but there is a noticeable difference between them in quality.
Re: Floor Jack [Re: rapom] #2656587
05/18/19 01:18 PM
05/18/19 01:18 PM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
They're all made in China. Get a Harbor Freight.
I recently got the aluminum one for my car to keep in the trunk. It works fine! $59 on sale...........
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
67 R/T Needs a bit of work
by 65pacecar. 02/19/20 10:09 AM
MUSCLECARS AT THE STRIP Mar 20-22 - LV
by moparts. 02/19/20 10:03 AM
Who's selling cast iron 426 Hemi Blocks?
by maximus. 02/19/20 09:33 AM
Any good paint and body men out there?
by Dartforforty. 02/19/20 09:24 AM
Moparts Recent Posts
Illegal to work on your own car in Sacramento county ?
by Pacnorthcuda. 02/19/20 10:34 AM
Found 1970 833 Transmission Case
by rarefish. 02/19/20 10:32 AM
87 Regal Turbo T - $19,500
by Pacnorthcuda. 02/19/20 10:27 AM
Unsafe site warnings on Moparts
by moparts. 02/19/20 10:22 AM
