Page 4 of 4 1 2 3 4
Re: pulsating driveline vibration? [Re: A727Tflite] #2654900
05/13/19 09:43 AM
05/13/19 09:43 AM
moparx Offline
moparx  Offline
transman, i don't know about the crankshaft, but watching a driveshaft spin at 1000rpm is visually terrifying to those who seldom watch something like that, and believe it or not, that is slow !
big truck shafts are spun slow because with their big tires and many other various vibrations present [at various frequencies] the shafts themselves spin at a slower rpm, plus are [usually] shorter than a car shaft and much, much larger in diameter [which absorbs vibrations] , so the multitude of vibrations and their frequencies tend to cancel each other out [somewhat].
car shafts need to be balanced at a faster speed, some as high as 5-6000rpm, due to overdrives, deep rear gears, and smaller diameter tires [i think denny's spins them as fast as 10k rpm eek. i saw their add in "nitro madness" magazine].
just because truck shaft places have been there for years, and have a great reputation, doesn't mean they have the newest high speed balancing equipment, simply because they do mostly truck shafts which don't require it.
beer
Re: pulsating driveline vibration? [Re: captaindodge] #2654944
05/13/19 11:49 AM
05/13/19 11:49 AM
pgh pa
captaindodge Offline
pgh pa
Originally Posted by captaindodge
Quote
I would be suspicious of the transmission mount.
Quote
So my suspicion might be correct. Maybe try a polyurethane trans mount to get that last little bit of vibration out.
Re: pulsating driveline vibration? [Re: captaindodge] #2655282
05/14/19 10:07 AM
05/14/19 10:07 AM
moparx Offline
moparx  Offline
i would think a poly mount may increase vibration due to it being a higher density material than rubber. this statement being based on several comments about suspension bushings and poly motor mounts causing vibrations to be transmitted into the cockpit. shruggy some notice this, some don't.
beer
Page 4 of 4 1 2 3 4
