Timing light upgrade recommendations? #2652870
05/07/19 08:57 AM
05/07/19 08:57 AM
NW New Jersey
RSI700VIPER Offline OP
NW New Jersey
My old craftsman timing light finally crapped out. What is everyone using these days? I understand there are timing lights where you can measure the timing by turning a dial on the unit.
1970 Superbird 440 Six BBL, 4-Speed, Dana, FJ5
1969 Daytona Charger 440 4-Speed, Dana, EV2
1971 340 Challenger Conv. Flemington Speedway Pace Car, FC7
1970 340 Six Pack Callenger T/A 4-speed T8 Tan
1971 340 Challenger RT Formal Roof, EV2 w/ V2 Stripe & Orange Houndstooth
1969 Talladega Torino, 428CJ
1969 Gurney Special Cyclone Spoiler II, 351 Cleveland
"Id rather have a bottle in front of me than a frontal lobotomy" Ben Franklin 1755
Re: Timing light upgrade recommendations? [Re: RSI700VIPER] #2652874
05/07/19 09:08 AM
05/07/19 09:08 AM
New York
rarefish Offline
rarefish  Offline
New York
Re: Timing light upgrade recommendations? [Re: rarefish] #2652891
05/07/19 09:43 AM
05/07/19 09:43 AM
Mequon, WI
gzig5 Offline
gzig5  Offline
Mequon, WI
I got the red Digital Pro version of that INNOVA light and it is really nice to use. A few more bucks but it has more features that you may or may not want.
Re: Timing light upgrade recommendations? [Re: gzig5] #2652926
05/07/19 11:12 AM
05/07/19 11:12 AM
Colorado front range
BcudaChris Offline
BcudaChris  Offline
I have not had good luck with the Inova units. They are of quality construction as far as the case, leads, etc., but of the three I had over a three year period, only one failed while it was still under warranty. The warranty replacement, after a year and about three uses, just started going flaky during use, intermittently flashing, tach being way off, voltmeter being wrong, completely going off while connected, etc. (I'd guess that was due to sloppy soldering on the circuit board). I tried swapping lead sets to no avail. The next one I bought blew the strobe after about three uses and sitting for over a year between uses. They were all the pro units.
That said, the strobe was nice and bright, the features and interface are useful and handy, and the detachable leads ability to change the angle of the strobe and case are also nice. I explored replacing the strobe with their tech support, and the bulb was $60 plus shipping.
I'm currently using the Bosch one they sell at O'Reilly's. Not as feature packed and is definitely of chintzier construction than the Inova, but over a year now and no fails. Also, O'Reilly's will swap it out easily enough in the event of a fail. Leads are hardwired in, no case and the display is an LED panel instead of LCD.
Dial-back feature is almost a must with my aging eyes, even though my damper is laser etched up to 60*.
Re: Timing light upgrade recommendations? [Re: BcudaChris] #2652957
05/07/19 12:27 PM
05/07/19 12:27 PM
My take, dialbacks ain't 100% accurate cuz there are different dia (circumference) balancers out there plus the additional error potential from the delay feature (might all be miniscle/not enough to sweat) but they are so much fun to play with! For dead on I prefer to get a timing tape (install & spray it with clear paint to keep it from flying off) or mark the dampener & you only need 4 or 5 numbers such as 15/20/25/30 & your preferred total for your engine type. 0.0632683" is (1) degree. I would get a light with the RPM feature in the dial.
Wouldn't hurt to check numbers with a non dialback & to confirm true TDC
Re: Timing light upgrade recommendations? [Re: RapidRobert] #2652962
05/07/19 12:37 PM
05/07/19 12:37 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Still using my old snap on dial light.
Its at least 25 years old
Re: Timing light upgrade recommendations? [Re: gtx6970] #2652969
05/07/19 12:48 PM
05/07/19 12:48 PM
SoMd, USA
135sohc Offline
135sohc  Offline
SoMd, USA
And it was probably made here.. Not so much for the new stuff.
I still use the same ancient craftsman unit my dad bought new in 198? old enough the entire housing is chromed aluminum and the leads are nice flexible rubber.
Re: Timing light upgrade recommendations? [Re: 135sohc] #2652973
05/07/19 12:53 PM
05/07/19 12:53 PM
One of the ign companies way back (MSD?) did a comprehensive study on accuracy & they said the old Craftsman was the best (not sure if this was dialback or not but I am thinking no).
Re: Timing light upgrade recommendations? [Re: 135sohc] #2652984
05/07/19 01:35 PM
05/07/19 01:35 PM
BDW Online content
BDW  Online Content
Same here, if it ain’t broke, don’t fix it..........
Re: Timing light upgrade recommendations? [Re: BcudaChris] #2652992
05/07/19 02:09 PM
05/07/19 02:09 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
iagree and am also using a Snap on that i picked up used beer
Re: Timing light upgrade recommendations? [Re: TJP] #2653048
05/07/19 03:49 PM
05/07/19 03:49 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
Multiple spark ignitions wreak havoc with dial back timing lights
Most guys with MSD have better luck with the old Craftsman lights for that very reason
Re: Timing light upgrade recommendations? [Re: RapidRobert] #2655120
05/13/19 07:53 PM
05/13/19 07:53 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
Dial back lights do not care what the balance diameter is.
If there is a zero, it will light it up.
Next mention is a dial back is the only way to fully set the initial, total and full advance as long as zero is marked.
Re: Timing light upgrade recommendations? [Re: Magnum] #2655131
05/13/19 08:13 PM
05/13/19 08:13 PM
ontario canada kingston
aspenrt360 Offline
aspenrt360  Offline
I have an OTC dialback that i paid a fair bit for many years ago it works just fine.
2013 Chrysler 300 touring 1974 Dodge Charger SE. 360-727-8.75-3.23 sure grip 1972 Dodge Dart Swinger 1995 Dodge Ram 1500 4x4
Re: Timing light upgrade recommendations? [Re: Magnum] #2655132
05/13/19 08:18 PM
05/13/19 08:18 PM
5thAve Offline
5thAve  Offline
A lot of dial back lights have problem with accuracy.
The only down side of a normal light is you need timing tape if you are into really setting the advance, or your base timing is past the marks on the engine.
Re: Timing light upgrade recommendations? [Re: aspenrt360] #2655137
05/13/19 08:28 PM
05/13/19 08:28 PM
Charlotte, NC
Kowal Offline
Kowal  Offline
Charlotte, NC
Same, been using an OTC light for years, works great. Burnt the cables once on the exhaust, they sold me a replacement very quickly.
'69 Hemi Charger 500, ‘70 U code Challenger R/T
(These and a bunch others at www.dkowal426.com)
P.J. O'Rouke: "The old car ran perfectly, right up until it didn't."
