For Genius's only. Smarter than me.
#2655023
05/13/19 03:53 PM
05/13/19 03:53 PM
Posts: 288 Nevada
merpar
Nevada
My 483 ci. wedge. Has 6 mild passes, not one full throttle pass on motor. Backed car out to line up and load on trailer, pulled up to ramp. Just as I started to shut it off it developed a rattle in the motor. Not a rod or lifter noise, was like something loose. Got it home and jacked up the front end. Pulled valve covers off and oil pan. Everything looks perfect, not a scratch or ding visible. Rocker arms, push rods, valves, and springs all woking and intact. Took all the plugs out and hit the starter, spun over clean and quiet. So decided to let car down and put up on blocks. Just as it was almost all the way down I heard a clink, best discrip. I can think of. Was going to turn it over by the crank and check each cyl. rockers. Put a long ratchet on it and bingo. It would not move, what ever clinked wedged somewhere and can't turn the motor either direction. Pulled the drive shaft and the trans. turns using the output shaft. And looking at the flex plate and convertor, what I can see. Nothing. Any help on this would be deeply appreciated. Short of pulling the motor and trans I'm stumped !!!!! Help!!!!!
Re: For Genius's only. Smarter than me.
[Re: merpar]
#2655027
05/13/19 04:00 PM
05/13/19 04:00 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Try priming the engine. Could be a broken oil pickup tube.
[Re: merpar]
#2655051
05/13/19 04:41 PM
05/13/19 04:41 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Pull the starter and see if you can move it with a long screw driver on the ring gear.. if not your gonna have to pull the trans(slide it off the conv while the conv is still bolted to the engine..or pull the engine and trans together so you can get it apart
[Re: MR_P_BODY]
#2655063
05/13/19 05:10 PM
05/13/19 05:10 PM
Posts: 20,158 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I had to cut off a backed off convertor bolt laying on my back at Norwalk 25 years ago. I had to use a hacksaw blade holding it in my hand because it was jammed up top. Never even missed a time trial but what a pain in the butt.
[Re: merpar]
#2655135
05/13/19 08:22 PM
05/13/19 08:22 PM
Posts: 1,823 Wind Gap,Pa.
Sammy
Wind Gap,Pa.
Am thinking we're on the right track. Started to remove the trans this afternoon, but at 75 yrs old pooped out. What a pain, flex plate shield, trans blanket tabs. And cutting off a bolt with a hack saw blade in hand. Not at my age. I'll break out the air tools tomorrow. Thank you everyone for your input. Will keep you informed on what I find. May have to wait till weekend if I can talk my son into helping. Thanks I'm right behind you nearing 70. I found that doing a little, walking away a few times during the day, you get more accomplished. I'm sure you'll find the problem and good luck.
[Re: Sammy]
#2655139
05/13/19 08:37 PM
05/13/19 08:37 PM
Posts: 4,669 Wichita
GY3
Wichita
Mine did the same thing last fall. Thought it was a torque converter bolt. Turned out to be the jankety 440Source balancer came apart and was bouncing off the timing cover.
[Re: Cab_Burge]
#2655250
05/14/19 08:15 AM
05/14/19 08:15 AM
Posts: 13,354 Marion, South Carolina [><]
an8sec70cuda
It does sound like a converter bolt issue. I always coat mine in red Loctite and try to let em cure overnight before firing the motor. That and I only use the ARP converter bolts after having issues w/ the piece of crap MP bolts that would stay tight no matter what I did.
[Re: merpar]
#2656978
05/19/19 07:00 PM
05/19/19 07:00 PM
Posts: 14,492 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
It wasn't a lifter dinged, it was the last lobe on the cam. That doesn’t usually turn out very well.
[Re: merpar]
#2658332
05/23/19 10:35 AM
05/23/19 10:35 AM
Posts: 288 Nevada
merpar
Nevada
Unbolted the flex plate. Nothing there and not any positive proof that anything had been there. Checked every rod bolt, didn't go to full torque. Enough to know that was not the problem. Turned the motor over by hand, with a light and checked every cylinder. Very carefully looked at everything. Not a sign of any dings or scratches. Rechecked rocker arms, valves, springs and everything I could think of. Whatever it was at one point fell out or vaporized. So,,,,,, my son and haven't asked my nephew yet, we are putting the motor back together this weekend and put the car back together. With a prayer !
[Re: merpar]
#2658347
05/23/19 11:11 AM
05/23/19 11:11 AM
Posts: 17,840 S.E. Michigan
ZIPPY
S.E. Michigan
Turned the motor over by hand To recap....first it was totally locked up in both directions, then you unbolted the flexplate, and now you can turn it over by hand? If I read this correctly (maybe I didn't), it kind of seems like a clue there
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#2658458
05/23/19 04:08 PM
05/23/19 04:08 PM
Posts: 2,105 Byron, NY
W.I.N. Racing
Byron, NY
Turned the motor over by hand To recap....first it was totally locked up in both directions, then you unbolted the flexplate, and now you can turn it over by hand? If I read this correctly (maybe I didn't), it kind of seems like a clue there " Well, have narrowed it down. My nephew came over Friday afternoon, we pulled the tranny. Still locked up. Pulled the damper, timing cover water pump. Everything was clean and good. Still locked up. Had this old man up till 10:00 with parts and tools scattered all over the shop. Bob suggested I pull the valve train. T&D set up, which made it easier. Saturday, took right side first. Still locked up!!!!! Took off left side, Walla, freed motor up. Pulled all the lifters, #7 one lifter had a small ding in it. Everything else looked perfect. Still haven't found the culprit that was rattling."Is what he posted prior
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: W.I.N. Racing]
#2658459
05/23/19 04:12 PM
05/23/19 04:12 PM
ZIPPY
S.E. Michigan
Turned the motor over by hand To recap....first it was totally locked up in both directions, then you unbolted the flexplate, and now you can turn it over by hand? If I read this correctly (maybe I didn't), it kind of seems like a clue there " Well, have narrowed it down. My nephew came over Friday afternoon, we pulled the tranny. Still locked up. Pulled the damper, timing cover water pump. Everything was clean and good. Still locked up. Had this old man up till 10:00 with parts and tools scattered all over the shop. Bob suggested I pull the valve train. T&D set up, which made it easier. Saturday, took right side first. Still locked up!!!!! Took off left side, Walla, freed motor up. Pulled all the lifters, #7 one lifter had a small ding in it. Everything else looked perfect. Still haven't found the culprit that was rattling."Is what he posted prior Thanks. It's too much lol. The lifter with a ding in it probably points to the next place to look.
Rich H.
Esse Quam Videri
[Re: moparx]
#2659668
05/27/19 03:10 PM
05/27/19 03:10 PM
W.I.N. Racing
Byron, NY
i can appreciate full thread engagement, but bottoming the bolt is worse than having a few threads short. if you have a thread or two more engagement than the bolt diameter, that is all it needs. Here is a rule of thumb that you cant go wrong with 1 X thread diameter in steel 1.5 X thread diameter in cast, bronze etc. 2 X thread diameter in aluminum Any more than that is of little gain (fastener will usually break first) any less and dramatically reduces strength and threads will pull.
[Re: W.I.N. Racing]
#2659912
05/28/19 10:20 AM
05/28/19 10:20 AM
Posts: 19,342 north of coder
moparx
i can appreciate full thread engagement, but bottoming the bolt is worse than having a few threads short. if you have a thread or two more engagement than the bolt diameter, that is all it needs. Here is a rule of thumb that you cant go wrong with 1 X thread diameter in steel 1.5 X thread diameter in cast, bronze etc. 2 X thread diameter in aluminum Any more than that is of little gain (fastener will usually break first) any less and dramatically reduces strength and threads will pull. correct. i was just using the example for steel because it was a flexplate/converter application. as for aluminum, if possible, i like helicoils [or variations thereof] or studs, still using the 2 times thread diameter.
[Re: merpar]
#2659928
05/28/19 10:47 AM
05/28/19 10:47 AM
Posts: 20,158 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I always hated Mopar convertors because of how they bolt up. I love the thru bolt setups that they used on the GM convertors
