69 440 6bbl.
If it set for weeks fuel pump won't prime or the carb is not giving gas? Pour some gas down the carb ...and it will fire up. Not an issue unhless it set for extended period.
Replace fuel pump or,accelerator pump diaphram on the carb seeems to be likley cause, but what is the purpose of the "canister" on the outlet line going to carbs.... filter, emissions ? about the size of a rattle can top ?
Could this be part of the issue ?
All good suggestions - checking for condition of rubber lines, fuel pump pushrod condition etc. if they are all good maybe this below should be considered.
Maybe just disconnect the fuel line from the pump outlet up to the vapor canister and crank the engine and see if you get pump output. If so, then do the same at the canister output. Possibly the return line to the tank from the canister is allowing too much fuel return after setting. Aftermarket return orifices appear to be too large in some repop examples. The production canister is pretty small.
Another test would be to then pinch off the return line to the tank and see if the line to the carb gets primed.
