Page 3 of 3 1 2 3
Re: Headers for my 499" B1MC headed Bonneville bullet [Re: mopar dave] #2654215
05/11/19 12:35 AM
05/11/19 12:35 AM
near St Petersburg, FL
Lifsgrt Offline OP
Lifsgrt  Offline OP
Finished my first set of headers a while back. 2 1/4" to 2 3/8" with 4" collectors. Just sent them to Jet Hot for coating!
B3 1969 Charger R/T SE, 440/727 with 3:91s running 11.07@120
Re: Headers for my 499" B1MC headed Bonneville bullet [Re: Lifsgrt] #2654216
05/11/19 12:41 AM
05/11/19 12:41 AM
Lifsgrt Offline OP
Lifsgrt  Offline OP
Right side. This one removes with only removing a couple of the plugs. Driver's side requires removing steering column and starter, plus a couple plugs. At least I don't have to move the engine!
Re: Headers for my 499" B1MC headed Bonneville bullet [Re: Lifsgrt] #2654218
05/11/19 12:49 AM
05/11/19 12:49 AM
MR_P_BODY Offline
MR_P_BODY  Offline
If you do a couple of things to them you will save them from cracking..
cut each tube where they are tied together and drill one of the 2 holes
on each tube a little bigger(doesnt matter what size hole).. that way they
can grow with the heat( they will expand so they need to slide a bit)
or they worp .. looks good.. I built a ton of headers at Chrysler
EDIT
this is a set I built for my W-9.. totally equal on all tubes
wave
Re: Headers for my 499" B1MC headed Bonneville bullet [Re: MR_P_BODY] #2654431
05/11/19 09:36 PM
05/11/19 09:36 PM
Lifsgrt Offline OP
Lifsgrt  Offline OP
Mr P Body, you're saying cut the flange between the tubes?
Re: Headers for my 499" B1MC headed Bonneville bullet [Re: Lifsgrt] #2654440
05/11/19 10:11 PM
05/11/19 10:11 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Yes I am.. after you trim them up nicely then drill one bolt hole a little
larger per tube
wave
Re: Headers for my 499" B1MC headed Bonneville bullet [Re: MR_P_BODY] #2654453
05/11/19 11:00 PM
05/11/19 11:00 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Mr. P! Check out those flanges he's using. I wouldn't cut them. Elongate the holes and be done. The only time I have cut flanges is for ease of R&R. Nice job Lifsgrt!
Re: Headers for my 499" B1MC headed Bonneville bullet [Re: Dave Hall] #2654456
05/11/19 11:13 PM
05/11/19 11:13 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Still gonna need to cut them.. they may worp in those areas or not..
but if you cut them that guarantees that they move.. just needs the
bigger hole in each tube
wave
Re: Headers for my 499" B1MC headed Bonneville bullet [Re: Lifsgrt] #2654482
05/12/19 01:19 AM
05/12/19 01:19 AM
Do you think the collectors need to be that long for that motor and the racing your doing?
What are your plans for the operating range in RPM for that motor off of the push car?
Re: Headers for my 499" B1MC headed Bonneville bullet [Re: Dave Hall] #2660981
05/31/19 03:32 PM
05/31/19 03:32 PM
Lifsgrt Offline OP
Lifsgrt  Offline OP
Thanks Dave!
Re: Headers for my 499" B1MC headed Bonneville bullet [Re: Cab_Burge] #2660983
05/31/19 03:35 PM
05/31/19 03:35 PM
Lifsgrt Offline OP
Lifsgrt  Offline OP
Hey Cab, I had not cut the collectors in these pics and they were still 18" long. I cut them at 13.4" from the ends of the tubes based on Pipemax data and other input I received prior to shipping them to Jet Hot for coating. It will be interesting to see how much steam this engine makes with my first effort at headers!
Re: Headers for my 499" B1MC headed Bonneville bullet [Re: Lifsgrt] #2755013
03/23/20 01:14 PM
03/23/20 01:14 PM
Lifsgrt Offline OP
Lifsgrt  Offline OP
Hey guys, update on my 498" Bonneville bullet using THE Block. I cut the collectors to 13.4" and had them Jet Hot coated. Finally got it on the dyno at Best Machine. This endurance build with a single Quick Fuel Dominator made 947hp at 7400rpm and 690tq at 6800rpm through my first time built 2 1/4"-2 3/8"-4" collector stepped headers that fit inside the frame rails of my Daytona clone. I now wish I'd have gone with the recommendation of a 4 1/2" collector. Engine ran better with a 4" to 5" adaptor on the collector. I tried 4" extensions at 54" long in hopes of getting the exhaust out from under yhe car for speed runs and it killed 35 hp. Will try 5" extensions and see if that works.
Re: Headers for my 499" B1MC headed Bonneville bullet [Re: Lifsgrt] #2756097
03/26/20 02:29 AM
03/26/20 02:29 AM
Lifsgrt Offline OP
Lifsgrt  Offline OP
Dyno info.
Thanks again for the input, I appreciate it. Got the flanges, collectors, and other tubing bits and pieces from http://www.spdexhaust.com/ They have custom flanges that fit these Brodix B1 MC heads very well.
Re: Headers for my 499" B1MC headed Bonneville bullet [Re: Lifsgrt] #2756277
03/26/20 07:59 PM
03/26/20 07:59 PM
NC
440Jim Offline
440Jim  Offline
NC
I enjoyed this topic! wave
Re: Headers for my 499" B1MC headed Bonneville bullet [Re: 440Jim] #2756281
03/26/20 08:13 PM
03/26/20 08:13 PM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
iagree Cool project and goals ! beer
Mark
http://marsh-racing.com/Mark%20Mahorney-Allstate.htm
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: Headers for my 499" B1MC headed Bonneville bullet [Re: Lifsgrt] #2756329
03/26/20 10:47 PM
03/26/20 10:47 PM
It wouldn't surprise me one bit if the car ran faster with longer collector extension instead of a lot shorter one scope
All the 4 speed cars I drag raced ran quicker and faster with longer collectors, which wasn't suppose to work up shruggy work
Take a set along and test them if and when you can up twocents
Re: Headers for my 499" B1MC headed Bonneville bullet [Re: Cab_Burge] #2762416
04/10/20 04:55 PM
04/10/20 04:55 PM
Lifsgrt Offline OP
Lifsgrt  Offline OP
Will definitely check that out, thanks!
Re: Headers for my 499" B1MC headed Bonneville bullet [Re: 440Jim] #2762483
04/10/20 08:43 PM
04/10/20 08:43 PM
Upland, California
Spode Offline
Spode  Offline
Upland, California
Re: Headers for my 499" B1MC headed Bonneville bullet [Re: Spode] #2762605
04/11/20 09:16 AM
04/11/20 09:16 AM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
how long are the primary tubes ?
....BAD A$$ STREET CAR.....
Re: Headers for my 499" B1MC headed Bonneville bullet [Re: n20mstr] #2779910
05/30/20 11:10 PM
05/30/20 11:10 PM
Lifsgrt Offline OP
Lifsgrt  Offline OP
2 1/4" x 9"
2 3/8"× 17"
4" collector 13.4" long. In retrospect I should've went with a 4 1/2" colle tor.
Also, after engine shop spec d a 1250 Dominator, I spoke with BRE and sent them my 1150 Dominator for modification. Bob Book thinks that will work better. With the new 1250 QF, peak tq was 690 @ 6800-6900, peak hp was 947 @ 7400-7500, which Bob and others think should be further apart.
Page 3 of 3 1 2 3
