Re: 6bbl fuel pump won't prime
[Re: gygeneral]
#2654263
05/11/19 09:39 AM
05/11/19 09:39 AM
RapidRobert
As said fuel evap & not sure why (how it is formulated) but it is worse than ever now even with non ethanol
[Re: mopars4ever]
#2654283
05/11/19 10:25 AM
05/11/19 10:25 AM
RapidRobert
I've had a weak pump along with a slow cranking speed make em not want to prime on their own.
[Re: RapidRobert]
#2654287
05/11/19 10:34 AM
05/11/19 10:34 AM
Posts: 13,581 md
mopars4ever
md
Yes, replacing a weak/bad pump is the obvious choice but I was warning him to check the hoses first before ordering one . I didn`t want him to run into the same issue as me.
[Re: mopars4ever]
#2654290
05/11/19 10:38 AM
05/11/19 10:38 AM
RapidRobert
Oh I totally agree with you brother (hoses are problematic/checking em is free). It is a logical 1st step.
[Re: 420SIX]
#2654324
05/11/19 01:04 PM
05/11/19 01:04 PM
Posts: 10,713 North Dakota
6PakBee
North Dakota
I have been dealing w/evaporating gas for decades, thats not the issue this time.
If carb bowles are dry you just crank it until they fill up and off you go. This is different...you could crank until the battery goes dead and no fuel....After it fires up with a squirt down the carb...it starts and runs just fine, until it sets for a few weeks Okay, I'll ask the obvious question, what is the difference between a squirt down the carb from something and a squirt down the carb from the accelerator pump? On my '67 Belvedere with a 273 two barrel, after it has sat for quite a while it takes about two minutes of cranking (with breaks) to get the engine to fire. And yes, my accelerator pump does not function when I start.
