Six Pack Fuel Lines #2652300
05/05/19 03:49 PM
05/05/19 03:49 PM
South San Francisco, Ca
70sixpkrt Offline OP
Who sells the best fuel lines that don't leak? My ends are starting to round out and I'm looking for a new set. My fuel lines currently don't leak.
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: Six Pack Fuel Lines [Re: 70sixpkrt] #2652343
05/05/19 06:01 PM
05/05/19 06:01 PM
70duster340 Offline
70duster340  Offline
Fine Lines!👍
Re: Six Pack Fuel Lines [Re: 70duster340] #2652354
05/05/19 06:36 PM
05/05/19 06:36 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I've used nothing but FineLines stainless steel 6 pack fuel lines over the years on several vehicles, zero leaks, just remember to use the correct fuel line wrenches, and put a lubricant on the threads before tightening any lines
Re: Six Pack Fuel Lines [Re: DAYCLONA] #2652400
05/05/19 09:14 PM
05/05/19 09:14 PM
Thanks. I always use the correct fuel line wrenches but taking them off and on for fine tuning for 15 years they are rounding off.
4-speed
3:54 Dana
Re: Six Pack Fuel Lines [Re: 70sixpkrt] #2652626
05/06/19 01:48 PM
05/06/19 01:48 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I always use a small dab of bearing grease on the threads.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Six Pack Fuel Lines [Re: 6PKRTSE] #2652736
05/06/19 07:50 PM
05/06/19 07:50 PM
Cab_Burge Online work
Cab_Burge  Online Work
Why ?
Re: Six Pack Fuel Lines [Re: Cab_Burge] #2654120
05/10/19 06:51 PM
05/10/19 06:51 PM
Chicago
PurpleBeeper Offline
Chicago
Have you ever tried taking those lines off? At least one seems to get stuck every time. I think I might try bearing grease myself next time
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: Six Pack Fuel Lines [Re: PurpleBeeper] #2654142
05/10/19 07:57 PM
05/10/19 07:57 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
If you want to make it real easy,flare a piece of 5/16 copper tubing,cut off the flare and insert in fitting,you'll only need one wrench to remove and you'll never have any leaks !!!
Re: Six Pack Fuel Lines [Re: 62maxwgn] #2654150
05/10/19 08:33 PM
05/10/19 08:33 PM
Do you have a picture for an illustration?
4-speed
3:54 Dana
Re: Six Pack Fuel Lines [Re: 70sixpkrt] #2654153
05/10/19 08:35 PM
05/10/19 08:35 PM
I bought the ones from FineLines. The only problem is that the blocks don't look like the originals did.
4-speed
3:54 Dana
Re: Six Pack Fuel Lines [Re: 70sixpkrt] #2654163
05/10/19 09:05 PM
05/10/19 09:05 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Not really,just cut off the flare,put in the fitting,screw in nut and you're done.
Maybe this will explain.A little more than involved than necessary but same principal but cutting off the flare is a little easier.
https://www.youtube.com/watch?v=u7WULLs2nV8
Re: Six Pack Fuel Lines [Re: 62maxwgn] #2654416
05/11/19 08:41 PM
05/11/19 08:41 PM
upstate western ny
sogtx Offline
sogtx  Offline
upstate western ny
A little oil on threads dont hurt too
Re: Six Pack Fuel Lines [Re: sogtx] #2654632
05/12/19 01:52 PM
05/12/19 01:52 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
