Re: 70 ebody master cly repair kit
[Re: dragon slayer]
#2688366
08/16/19 11:02 AM
08/16/19 11:02 AM
Posts: 203 Alabama
David1971
Alabama
A picture to ensure you have the correct OEM would help. But that is the common Drum MC from 67 to 70. Those are still available after market like rock auto, and several on Ebay if you want Mopar OEM. From a fellow member, I purchased a 2225601 master cylinder for my 1970 U-code Cuda . Does this Wagner rebuild kit (F104474) look correct for the 601 casting?
[Re: David1971]
#2688593
08/16/19 10:46 PM
08/16/19 10:46 PM
Posts: 8,341 Crook County, ILL
Mastershake340
Crook County, ILL
On the drum kit, sorry I couldn't respond to your last PM. I was in OH last weekend and working until late most evenings since I got back! Here are pictures of pistons in an NOS kit I have for the drum MC. Not sure why the aftermarket kit has a retaining ring, the original MC's didn't have a retaining ring, the power brake versions used a retaining clip, and the non power had a ring with the dust boot.
[Re: David1971]
#2689013
08/18/19 10:21 AM
08/18/19 10:21 AM
Posts: 1,321 VA
dragon slayer
VA
