Re: Sanity check: roofing cost [Re: calmopar] #2622668
02/17/19 07:12 PM
02/17/19 07:12 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Commercial is double or triple cost for just about anything, try to hire an electrician that does commercial...or a plumber...
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Sanity check: roofing cost [Re: calmopar] #2622784
02/18/19 12:19 AM
02/18/19 12:19 AM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
I'm in the roofing business in Minnesota. On a layover of that size, I'd be in the $7 - 12 per square foot range, unless there was a lot of new sheet metal to fab up and install, That might push it up another $1000 or so.
So to me, your bid seems really high. I'd shop a lot more.
[img]http://img4.imagetitan.com/img.php?image=20_16_carbs.jpg[/img]
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Sanity check: roofing cost [Re: calmopar] #2624902
02/22/19 09:22 PM
02/22/19 09:22 PM
Bradenton, Fl 34203
Kilroy was here Offline
Bradenton, Fl 34203
$16,000. 2100sf total roof. Replace a LOT of plywood, like 14 sheets. No leaks after three years.
Re: Sanity check: roofing cost [Re: calmopar] #2626018
02/25/19 06:30 PM
02/25/19 06:30 PM
East Bay, N. Cal.
calmopar Offline OP
calmopar  Offline OP
East Bay, N. Cal.
Thanks for all the input. My neighbor went up there with me to check it out (he's not a roofer, just a generally smart and handy guy). He checked out the roof, looked around at everything from inside and outside and pointed out to me that the roof itself looked fine but it was obvious that the skylights were leaking and the water was traveling on top of the insulation over to the walls. I took a closer look and sure enough...they are leaking.
So first things first, I suppose - seal up the skylights and replace the water-logged insulation and see if that solves the problem.
I am going to get a couple of more estimates as suggested here.
Trying to enjoy life!
Re: Sanity check: roofing cost [Re: calmopar] #2626524
02/26/19 09:50 PM
02/26/19 09:50 PM
the great wet north
Superfreak Offline
Superfreak  Offline
the great wet north
Do yourself a favor and get rid of the skylights. Most idiotic thing ever invented for a roof, be it a house or commercial building.
"Too much to do and not enough time to do it"
Re: Sanity check: roofing cost [Re: Superfreak] #2653545
05/08/19 10:10 PM
05/08/19 10:10 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
What was the result of getting more estimates?
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Sanity check: roofing cost [Re: lilcuda] #2653548
05/08/19 10:23 PM
05/08/19 10:23 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
House we sold back in KY needed a roof. received 3 estimates. ranging from $8k to $16k
Cheapest one was a simple lay over.
top one was down to plywood and start over ( if wood needed repairs costs would rise ) with lifetime warranty shingles ( fyi, lifetime isnt really lifetime )
I wasnt putting that kind of money in the house that would never be recovered in the sale
I hired a local guy who worked for a roofer to do it on the side. Cost me right about $2200 in materials and $2000 in labor. took them 3 weekends start to finish, it was a layover.
ps, if you go this route draw up a contract for liability issues ( if they happen to fall its on YOUR insurance )
Re: Sanity check: roofing cost [Re: gtx6970] #2653653
05/09/19 09:56 AM
05/09/19 09:56 AM
Bradenton, Fl 34203
Bradenton, Fl 34203
$16,000... Shingles, and 20 sheets of plywood replaced.
2200 SF, Florida home, wood frame built, 1981
No leaks, and we have heavy rain here.
Gain 13-Plus-Rear Wheel Horsepower With Hughes Engines
by Rustymuscle. 01/23/20 01:48 AM
O/T three phase motor amperage question
by Hemi_Joel. 01/23/20 01:28 AM
brake line clip & retainer locations
by buzz440. 01/23/20 12:27 AM
69 Roadrunner Interior Panel Fitment Issue
by BigDaddy440. 01/22/20 10:12 PM
Moparts Recent Posts
Aluminum 8 3/4 center section P4876445
by Doc Fiberglass. 01/23/20 01:10 AM
Wow, '18 WB Hellcat with 101k miles
by Doc Fiberglass. 01/23/20 01:04 AM
