727 Kickdown linkage cable options #2653554
05/08/19 11:54 PM
05/08/19 11:54 PM
IMGTX Offline OP
IMGTX  Offline OP
I am swapping the transmission out on my 74 440 B Body RR.
The old one died a premature death partially because of no kickdown linkage. The transmission has parts of the a 3 piece system on it but it isn't complete. I bought it that way so I don't know where the parts are or what was original.
1st Question. Didn't the 74 440's use the single linkage rod not the 3 piece rod and bellcrank system?
2nd Question does anyone repop the single rod systems for a 74 model?
Since it has a mid rise (higher than stock) intake I am thinking of a cable system.
3rd Question. Is there a good or bad brand of cable to buy or avoid?
4th Question. Has anyone modified a stock late model A518 cable for the purpose?
Re: 727 Kickdown linkage cable options [Re: IMGTX] #2653650
05/09/19 10:52 AM
05/09/19 10:52 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
If you go Cable, use the one made by https://www.bouchillonperformance.com/home
Re: 727 Kickdown linkage cable options [Re: CSK] #2653678
05/09/19 12:02 PM
05/09/19 12:02 PM
moparx Offline
moparx  Offline
i DO NOT LIKE the LOKAR cable setup. cheap brackets, a little [but not by much, just a few thousandths] thicker than cheap bicycle brake cable, almost impossible to adjust Properly.
STAY AWAY ! tsk
Bouchillon or the 518 style cable are your ONLY options of cable operated throttle valve control. just my opinion, your mileage may vary.
did i say i DON'T LIKE the LOKAR setup ? flame
beer
Re: 727 Kickdown linkage cable options [Re: moparx] #2653778
05/09/19 05:12 PM
05/09/19 05:12 PM
Leucadia, Ca.
V
vdriver Offline
vdriver  Offline
V
Leucadia, Ca.
I put the Bouchillon setup on a '70 Duster 360/727 about a year ago; the install was easy and it works great.
