Kit for bushing carb throttle shaft #2653278
05/08/19 07:42 AM
05/08/19 07:42 AM
Virginia
V
varunner Offline OP
varunner  Offline OP
V
Virginia
I've got a holley with a wore secondary throttle shaft. Does anyone know of a good kit with drill/reamer and bushings ? thanks
Re: Kit for bushing carb throttle shaft [Re: varunner] #2653396
05/08/19 01:05 PM
05/08/19 01:05 PM
WV
Little Detroit Offline
WV
you shouldn't have to ream the base plate of course I haven't seen yours, that being said Holley made provisions for that repair the throttle shafts a machined for nylon bushings and there are two different sizes . I have both if you need a couple , let me know how many you need ,
Re: Kit for bushing carb throttle shaft [Re: Little Detroit] #2653450
05/08/19 04:44 PM
05/08/19 04:44 PM
Virginia
V
varunner Offline OP
varunner  Offline OP
V
Virginia
this shaft is pretty sloppy. Seems like you'd have to be lucky to get a good fit without opening the hole. do you know the OD of the plastic bushing ?
Re: Kit for bushing carb throttle shaft [Re: varunner] #2653586
05/09/19 07:09 AM
05/09/19 07:09 AM
WV
WV
like I said previously I havn't seen yours, however that's why there are 2 different sizes, if its that sloppy your base plate may be toast.
Re: Kit for bushing carb throttle shaft [Re: Little Detroit] #2653608
05/09/19 09:11 AM
05/09/19 09:11 AM
Virginia
V
varunner Offline OP
varunner  Offline OP
V
Virginia
I already have what I need, but providing dimensions would be helpful to others if you know what you have. thanks !
Re: Kit for bushing carb throttle shaft [Re: varunner] #2653634
05/09/19 10:11 AM
05/09/19 10:11 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
The shaft is cut for the bushing,being that the bushing is split I imagine it would not be easy to measure,probably would need production specs.
