Re: Belt tensioner for old mopar BB
[Re: mopar dave]
#2653600
05/09/19 08:45 AM
05/09/19 08:45 AM
Posts: 8,031 Mt Morris Michigan
mopar dave
Mt Morris Michigan
Looking to put some electric fans on it. ECP cooling fan kit comes with 2 13" spal low profile fans, aluminum shroud and wiring kit for $550. Ouch. Tried piecing it together, but can't find the correct aluminum shoud 27x16 with 13" holes like they use.
[Re: mopar dave]
#2653617
05/09/19 09:38 AM
05/09/19 09:38 AM
Posts: 6,988 Warren, MI
Jerry
Warren, MI
right, but that little bit of extra cooling at idle won't give you much benefit with twin electric fans. if you look at a factory shroud, there is a large taper to it, so it draws the air into the fan. with the design you posted above you basically have a flat sheet pan with two holes cut into it. while driving that will restrict more air flow, as the air has to make to tight turn just past the core. like I said, the good versions of those shrouds that mount electric fans, have louvers or spring loaded doors that open at driving speeds.
