Gen 3 to A-Body #2652278
05/05/19 02:22 PM
05/05/19 02:22 PM
Warrenton, VA
RoadRunnerJD Offline OP
Warrenton, VA
New to this but just thinking about a Gen 3 conversion. Is there a kit made for bolting in a modern Hemi into my 69 A-Body? Can I make it work with my 4 speed or do I need a different trans?
Re: Gen 3 to A-Body [Re: RoadRunnerJD] #2652296
05/05/19 03:24 PM
05/05/19 03:24 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
There are lots of options out there from complete k frames to just mounts. Gen 3 hemi has the exact same bell pattern as the LA block, you just need the proper adapter for the crank.
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: Gen 3 to A-Body [Re: DemonDust] #2652311
05/05/19 04:13 PM
05/05/19 04:13 PM
Warrenton, VA
Warrenton, VA
Good info. Thank you.
Re: Gen 3 to A-Body [Re: RoadRunnerJD] #2652722
05/06/19 07:09 PM
05/06/19 07:09 PM
gregsdart Offline
gregsdart  Offline
I moched up a 5.7 with Jeep stainless steel stock SRT exhaust manifolds. I needed to trim the bell of the trans a touch just above the starter, and on an early A the torsion bars were right where those manifolds would exit. I put a rack and pinion and coilover system together along with coilover shocks and springs to make everything fit in the early a. There is a lot of info out there on a 69A to g3 swap, so i am certain there are easier ways to get it done than i did.
Re: Gen 3 to A-Body [Re: RoadRunnerJD] #2653847
05/09/19 09:46 PM
05/09/19 09:46 PM
Tx
loganscuda Offline
loganscuda  Offline
Tx
I put one in my 67 Cuda. TTI has the mounts, almost any trans will bolt up with adapter plates. Check out FABO website more info on Abody GENIII swaps. More companies are making kits for them now. I did mine in 2010.
Re: Gen 3 to A-Body [Re: RoadRunnerJD] #2654019
05/10/19 01:17 PM
05/10/19 01:17 PM
Columbus, OH
65Dodge440 Offline
65Dodge440  Offline
Columbus, OH
I'm putting a Gen 3 in my 68 Dart. I have TTI headers, their biscuit motor mounts and a remote oil filter kit with the block off plate. I have the ATI flex plate to match it to my 904 (manual valve body). MS3 gold box and their harness. Other than that, I don't plan on anything else. The engines not in the car yet, so that could change. I'm changing the cam, intake, lifters, etc... right now and then it goes in.
Re: Gen 3 to A-Body [Re: 65Dodge440] #2657041
05/19/19 09:40 PM
05/19/19 09:40 PM
Ontario, Canada
RealWing Offline
RealWing  Offline
Ontario, Canada
There are several options available for this installation. This is a link to my 6.1 install in a 1969 Barracuda.
If any questions, just PM me.
https://www.forabodiesonly.com/mopar/threads/srt8cuda-build.218445/
1970 Superbird 440-6bbl, auto
1969 Barracuda 340-4bbl, FB Formula S auto
1969 Barracuda 6.1 L Hemi, 5 speed, Convertible
2022 Can Am Spyder RTL
