Dumb engine break in question #2651490
05/03/19 09:46 AM
05/03/19 09:46 AM
Third rock from the sun.
busboy Offline OP
busboy  Offline OP
If I’m using Valvoline VR1 racing oil for my break in do I still need to use a liter of zinc additive? Motor is a roller 440, my thinking is it’s only the rings that need to seat.
Oh yeah, it's a hybrid.....it burns gas and tires!
Re: Dumb engine break in question [Re: busboy] #2651504
05/03/19 10:27 AM
05/03/19 10:27 AM
Mass
charge70 Offline
charge70  Offline
Mass
The VR-1 oil will have more than enough zinc in it.
1970 Dodge Charger R/T S.E. 1969 Dodge Dart GTS 440 M-Code 1970 Dodge Charger 500 383/4-speed w/A.C.
Re: Dumb engine break in question [Re: busboy] #2651514
05/03/19 10:49 AM
05/03/19 10:49 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Shouldn't be needed.
Rich H.
Esse Quam Videri
Re: Dumb engine break in question [Re: ZIPPY] #2651649
05/03/19 05:42 PM
05/03/19 05:42 PM
busboy Offline OP
busboy  Offline OP
Great, thanks for the replys up
Re: Dumb engine break in question [Re: busboy] #2651681
05/03/19 06:46 PM
05/03/19 06:46 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Like said, roller cam, not needed.
Re: Dumb engine break in question [Re: ZIPPY] #2651885
05/04/19 01:00 PM
05/04/19 01:00 PM
upstate western ny
sogtx Offline
sogtx  Offline
upstate western ny
Rotella Ok ?
Re: Dumb engine break in question [Re: busboy] #2652188
05/05/19 11:39 AM
05/05/19 11:39 AM
Happy Birthday RapidRobert  Offline
Quote
There are no dumb questions (only rude answers!) & rare on that. On the ring breakin my take is that you get one shot to get it right & get excellent leakdown numbers/minimal oil consumption) as opposed to good numbers. I had always went with the procedure at www.mototuneusa.com then someone on here said there procedure ain't quite right & posted another site (from a ring mfr iirc) but I cant find it.
Re: Dumb engine break in question [Re: RapidRobert] #2652485
05/06/19 08:50 AM
05/06/19 08:50 AM
E
earlymopar Offline
earlymopar  Offline
E
Robert: I had previously reviewed the Mototune method and find it to make good sense. The only question / concern I have with using this method is that it seems to focus on ring seating and has no reference/s to camshaft break-in or impact while using their ring seating method. I guess what this says is that the camshaft get's its break-in in parallel with the rings getting seated. I recall reading the Ronnie Sox would break-in his race car engines by making a few 1/4 mile passes. This somewhat follows the Mototune concept but also discounts or by-passes the typical camshaft break-in procedure most of us use.
- EM
