Electrical upgrade question. #2651844
05/04/19 11:22 AM
05/04/19 11:22 AM
MO
cdp Offline OP
cdp  Offline OP
MO
Added in a RT-engineering volt limiter in my 71 RR with factory tach. It seems in doing so, I've lost mounting for the ground. Or, I'm not sure where this ground with tracer goes. Any thoughts? Service manual and an extra nontach cluster for reference.
Anyone else do these upgrades on their 71/72 B/E BODY?
Re: Electrical upgrade question. [Re: cdp] #2651855
05/04/19 11:42 AM
05/04/19 11:42 AM
Pittsburgh, PA
Slotts Offline
Slotts  Offline
Pittsburgh, PA
You can make a short jumper with an eyelet to male Packard 59 terminal, 16 gauge wire would be fine. The eyelet could go between the VR and screw and the other side to the two conductor black wires.
Re: Electrical upgrade question. [Re: cdp] #2651951
05/04/19 05:11 PM
05/04/19 05:11 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Seem like I had an extra ground when I ddid the same thing, I think I just let it hang, but not 100% sure.
Re: Electrical upgrade question. [Re: cdp] #2652046
05/04/19 11:34 PM
05/04/19 11:34 PM
Shoreline, Washington
72roadrunnergtx Offline
Cut the mounting tab off the old one and install it over the existing mounting, under the same screw, connect the cluster ground. Or replace the spade connector on the ground wire, install a ring terminal, install it under the mounting screw. Would not recommend just leaving it disconnected, there is reason the ground wire exists.
1972 Road Runner GTX 440 6bbl 5-speed
[img]http://72rrgtx.com/carpics/bucket/DSC06730r-1.jpg[/img]
Re: Electrical upgrade question. [Re: cdp] #2652675
05/06/19 04:30 PM
05/06/19 04:30 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
I did it to a 73 Cuda. The mounting ground was sufficient for the RT regulator. Just hooked the octopus to the gauges on the stud and 12 V connector on to the blade. Has been installed for over five years now with all gauges reading properly.
Craig
