Re: Airplane gas use in car, any issues?
[Re: 73cuda340]
#2652080
05/05/19 06:36 AM
05/05/19 06:36 AM
Posts: 2,468 Answering the call of the wild
ThermoQuad
OP As you see there is lots of gas in the thread all that so called info is a lot of spent exhaust gasses I ran AVG as and unleaded blended together for over 20,000 miles. The engine was an 11:1 six pak small block. No issues ever. \ That engine was refreshed after 20k due to bad valve springs [chinese mopar performance valve springs]and there was not one issues found from running the evil av gas Adding av gas to unleaded premium raises the octane of the blend. It is not necessary to run pure av gas at all. If the car does not require it for octane it still might like a little lead in it's drink and make it run better. Every car is different Higher octane allows more timing which typicality brings in more HP and torque. Some engines respond really well to high octane gas and more timing advance. You have to determine the blend your car needs ie ratio of UL to AVG and stick to it. You do not have to reset the float levels ! BUT you do need to tune the cat for the type fuel you are running Yes dear the Air Fuel Ratios are different between fuels. Look it up! It will not ruin your motor. Hog wash It is typically illegal to pump AVG directly into a car but not illegal to purchase it in gas cans and use it for whatever you need it for.
[Re: ThermoQuad]
#2652218
05/05/19 12:32 PM
05/05/19 12:32 PM
Posts: 43,228 Bend,OR USA
Cab_Burge
[quote= It is typically illegal to pump AVG directly into a car but not illegal to purchase it in gas cans and use it for whatever you need it for. [/quote] I hope you never run into a cop that is on a mission to put law breaker into the justice system for using leaded fuel on a highway The fine is $10,000.00 the last time I heard of a person being convicted for that violation, not sure about how much jail time also
[Re: 73cuda340]
#2652456
05/06/19 07:01 AM
05/06/19 07:01 AM
Posts: 8,162 USA
360view
Moparts resident spammer
USA
Historically, Iodide was the first Octane improver found. Same stuff we used put on cuts as an antiseptic. It is still in drugstores. MMT is still made and used in place of Tetraethyl lead. https://en.m.wikipedia.org/wiki/Methylcyclopentadienyl_manganese_tricarbonylThe Ethyl Corporation once wanted to buy a company I had some stock in back in the 1970s but the other owners turned them down. Real bad outcome for me. My grandfather was put on the USA Council for Fuel Research in 1927 as the “coal guy”. I heard many interesting stories from him in the 1960s and 70s. CFR amongst many things invented the little engine with a variable compression ratio that is used to rate fuel Octane Number. Back then it was a top secret military project to boost Octane rating. One of the worst mistakes ever made was for the US Government to license and sell Germany a USA designed Tetra-Ethyl-Lead plant in the middle 1930s. Lucky we did not also sell them a Triptane plant. https://en.m.wikipedia.org/wiki/Triptanehttps://stason.org/TULARC/vehicles/gasoline-faq/10-1-The-myth-of-Triptane.html
[Re: ThermoQuad]
#2652482
05/06/19 08:40 AM
05/06/19 08:40 AM
Posts: 13,374 Marion, South Carolina [><]
an8sec70cuda
I ran it for years in a 12.5:1 440 w/ no problems. A friend of mine used to run it in a 13:1 BB Chevy spraying nitrous...low 5 sec 1/8 mile, ran it for years. I currently use it in a 14:1 440.
One thing I remember coming from an airplane guy is that the most strain put on an airplane's engine is on takeoff...not at altitude.
[Re: BcudaChris]
#2654001
05/10/19 11:49 AM
05/10/19 11:49 AM
Posts: 7,541 Albany, NY
67SATisfaction
The member whose name is actually Art
Albany, NY
When I was a practicing A&P in the late 80's/early 90's I was running a 10.0:1 (via milled 302 heads) 318 with headers, AFB, dual plane Wieand, 284/.484 purpleshaft. I'd run 25% 100LL with 85 unleaded (4 gallons of 100LL in a 16 gal tank). Engine really liked that with 37* (6kft) and I could bring it all in by 2500 without problems. I'd have to back off to 34 for 91 unleaded, and couldn't stand on it off the line to avoid detonation. Sure smelled good. I could fill it up with that combination for $15.
I have no performance metrics to share.
So, when I was working in a repair station on Continental and Lycoming airplane engines that ran 10LL exclusively, at 2500hr overhaul we'd knock the plug out of the crank snout and from behind the plug back to where the cranks got solid right before No.1 brg, would be packed with lead. Leather aprons, rubber gloves up to our elbows and face shields were worn while we used aluminum scrapers to literally get the lead out and it all had to go into a hazmat bin.
Lead in the blow-by mixes with the oil and through some act of physics and engineering would accumulate in that part of the crank. I was always told that there is too much lead in 100LL to run it uncut in an automotive application, and that its exclusive use (uncut) on the street would cause long term durability problems due to oil formulations and no place for the stray lead to collect, which would cause it to pack piston ring grooves as well as mucking up the PCV system. I know I'm late to the party here, but I'll share my experience - and my advice is stick to formulas meant for automotive applications, even just store-bought additives. When I was flying a lot, I ran a mixture with aviation 100LL (LL stands for Low Lead) in my stock '67 2bbl 383. I didn't need the octane, I wanted the lead. After about 1,000 miles I started getting detonation on hard throttle or steep uphills. Only then did I talk it over with my A&P mechanic who told me to stop immediately. He explained even "LL" aviation fuel has FAR higher lead content than automotive gas ever had. The formulations are really out of whack with what a car needs. He borescoped a couple of my cylinders and found a lot of lead deposits - which would naturally create hot spots and be prone to the detonation I was experiencing. I've never used aviation fuel since. My lesson was if it ain't formulated for a car, don't put it in. - Art
65 Satellite hardtop 361/4bbl console 727 2.76 67 Satellite convert 383/2bbl column 727 3.23 67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd 67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd 71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd 82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle 75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF 77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF 07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
[Re: 67SATisfaction]
#2654023
05/10/19 01:28 PM
05/10/19 01:28 PM
Posts: 25,881 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Only then did I talk it over with my A&P mechanic who told me to stop immediately. He explained even "LL" aviation fuel has FAR higher lead content than automotive gas ever had. "TEL remains an ingredient of 100 octane avgas for piston-engine aircraft. The current formulation of 100LL (low lead, blue) aviation gasoline contains 2.12 grams of TEL per gallon, half the amount of the previous 100/130 (green) octane avgas (at 4.24 grams per gallon), but only slightly less than the 2.2 grams per gallon historically permitted in automotive leaded gasoline and substantially greater than the allowed 0.001 grams per gallon in automotive unleaded gasoline sold in the United States today."
[Re: John_Kunkel]
#2654040
05/10/19 01:59 PM
05/10/19 01:59 PM
Posts: 403 Colorado front range
BcudaChris
Only then did I talk it over with my A&P mechanic who told me to stop immediately. He explained even "LL" aviation fuel has FAR higher lead content than automotive gas ever had. "TEL remains an ingredient of 100 octane avgas for piston-engine aircraft. The current formulation of 100LL (low lead, blue) aviation gasoline contains 2.12 grams of TEL per gallon, half the amount of the previous 100/130 (green) octane avgas (at 4.24 grams per gallon), but only slightly less than the 2.2 grams per gallon historically permitted in automotive leaded gasoline and substantially greater than the allowed 0.001 grams per gallon in automotive unleaded gasoline sold in the United States today." True, but the fuel formulation is different as the fuel needs to vaporize consistently at varying temperatures and altitudes. And at least back when I was in the industry, octane was calculated differently for AVGAS (Ried Vapor Pressure v R+M/2 if memory serves). The TEL is suspended in the fuel differently in AVGAS than it was back in the days of leaded automotive gas. Also, I'm quite sure, the amount of TEL in 100LL had dropped over the years. Like the fuel, oil formulations for AV engines are quite different than automotive formulations. Air cooled crank cases are hotter and the duty cycle is more of a steady state than the constant RPM changes automotive engines see. Combustion chamber "fuel cooling" is a thing in aluminum real HEMI head combustion chambers. You can richen the mixture during operation and watch the CHT and EGT drop. TEL contributes a lot to fuel cooling in the combustion chamber. When you drain the oil out of an AC engine that is run on leaded fuel, you can see the led swirling around in the oil, when you open up the oil filter led is gooked around all over the place. I don't recall that from the days of leaded gasoline. I imagine most of the TEL in unleaded automotive gas went out the tail pipe and not as much stayed in the engine as in an aviation application.
[Re: BcudaChris]
#2654066
05/10/19 03:05 PM
05/10/19 03:05 PM
John_Kunkel
Rio Linda, CA
Also, I'm quite sure, the amount of TEL in 100LL had dropped over the years. lication. The number posted ( 2.12 grams of TEL per gallon) is current as of October, 2018
[Re: John_Kunkel]
#2654128
05/10/19 07:19 PM
05/10/19 07:19 PM
Posts: 1,180 clarks summit pa
73cuda340
clarks summit pa
Ok thanks for the responses. I'll just play it safe and try to make a trip somewhere and stock up on non ethanol and add an octane booster to it. The closest one to me only has 90 octane non ethanol.
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip,
(JA5) Silver Frost Metallic
1973 Challenger Rallye 340
1985 W150 Power Ram prospector
1986 Camaro IROC-Z 305 tpi
[Re: NANKET]
#2654157
05/10/19 08:39 PM
05/10/19 08:39 PM
Posts: 595 Nashville, Tennessee
Tempest
The bottom line is, unless your motor "needs" more octane to prevent detonation, it will not make more power. Most (unless they built their own motor) don't know the "true" mechanical compression ratio. It's typically less than you think when you calculate ring land, deck height and valve reliefs.
[Re: 73cuda340]
#2654219
05/11/19 12:51 AM
05/11/19 12:51 AM
Posts: 247 DuPont, Washington
DZJim
DuPont, Washington
Are there any issues with running airplane gas in cars? There is a small airport by me that sells 100 octane airplane fuel that is ethanol free. This is the only ethanol free gas that I can find locally . Would this cause any issues with the motor, carburetors or fuel pump? Don't get caught evading tax! You do not want to come to the attention of the taxman...EVER! For any reason. They don't sleep and they don't forget, and very, very rarely do they forgive.
[Re: DZJim]
#2654301
05/11/19 11:33 AM
05/11/19 11:33 AM
Posts: 22,696 Bitopia
jcc
Bitopia
Are there any issues with running airplane gas in cars? There is a small airport by me that sells 100 octane airplane fuel that is ethanol free. This is the only ethanol free gas that I can find locally . Would this cause any issues with the motor, carburetors or fuel pump? Don't get caught evading tax! You do not want to come to the attention of the taxman...EVER! For any reason. They don't sleep and they don't forget, and very, very rarely do they forgive. Another member here mentioned never heard of anyone getting caught. We had a Fair ride concession get caught using his red dye diesel generator fuel in his OTR transport tractors, got a $50K fine, nobody likes to advertise getting caught I suspect. OT, I have used the same portable transfer pump for both fuels, and wonder what contamination between fuels would constitute a violation, since there is often some residual amount of fuel left in the pumps filter/lines.
