Re: Steering shaft removal
[Re: AndyF]
#2650688
04/30/19 09:59 PM
04/30/19 09:59 PM
RapidRobert
All I can add is on the early A bodies, the solid inner shaft just comes right out (from the bottom) once everything is undone up top (bearing/clip etc).
[Re: AndyF]
#2650718
04/30/19 11:13 PM
04/30/19 11:13 PM
Posts: 10,938 Spokane Valley, WA
Big Bad Bee
Spokane Valley, WA
Maybe the FSM instructions show best practice of removing the bearing without removing the shaft from the vehicle?
I’m listening.
[Re: AndyF]
#2650774
05/01/19 08:34 AM
05/01/19 08:34 AM
Posts: 20,622 in a cattle trailer down by th...
Guitar Jones
I have a FSM and it shows how to use a bearing puller to push the shaft out of the bearing in the column but a Mopar guy I was talking to the other day says he just taps the shaft out from below. The rubber bearing isolator is only a snug fit in the column so the whole assembly slides out without using a lot of force. So my question is if the shaft will come out fairly easily that way, then why does the FSM say not to do it? The bearing and the isolator have to come out anyway for replacement so why not just tap the shaft out with the bearing and then replace the parts on the bench? This is on my '65 Coronet so the shaft is solid without any plastic pins. The FSM procedure is the factory approved method probably so that nothing is damaged. Have you ever seen what some knuckle draggers can do with a hammer?
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: Stanton]
#2650786
05/01/19 09:20 AM
05/01/19 09:20 AM
Posts: 3,916 usa
lewtot184
usa
My guess is that the bottom bearing is exposed to moisture, dirt, etc and can potentially rust ad seize onto both the shaft and the tube. Trying to tap it out would snap the plastic pins. However, I have removed min a couple times by tapping from the top with no issues. '65's don't have a pinned shaft and to the best of my knowledge don't have a lower bearing.
[Re: Stanton]
#2650847
05/01/19 12:28 PM
05/01/19 12:28 PM
Posts: 3,916 usa
lewtot184
usa
There has to be a lower bearing of some sort !! maybe bubba got mine,..lol. all mine had was a plastic disc.
[Re: Stanton]
#2650964
05/01/19 04:47 PM
05/01/19 04:47 PM
Posts: 30,989 Oregon
AndyF
There has to be a lower bearing of some sort !! Not in the early floor shift columns. There might be something in the column shift setup. The floor shift column has a rubber and nylon type of seal arrangement at the bottom but not a bearing. Here are the two columns I'm working with. I need to convert my red column over to PS from manual steer so I'm parting out the blue column and putting the parts in my red column.
[Re: AndyF]
#2651063
05/01/19 09:52 PM
05/01/19 09:52 PM
RapidRobert
that is what I was doing with my early A, swapping the inner shafts to go to power steering, piece of cake & yours look like the same type. I would dig in & you'll know quick if you need to regroup on your procedure.
[Re: AndyF]
#2651158
05/02/19 10:19 AM
05/02/19 10:19 AM
Posts: 16,127 Mesa, Arizona
dart4forte
Mesa, Arizona
There has to be a lower bearing of some sort !! Not in the early floor shift columns. There might be something in the column shift setup. The floor shift column has a rubber and nylon type of seal arrangement at the bottom but not a bearing. Here are the two columns I'm working with. I need to convert my red column over to PS from manual steer so I'm parting out the blue column and putting the parts in my red column. So the longer shaft is for the manual box?
Abe Lincoln
[Re: AndyF]
#2651218
05/02/19 01:12 PM
05/02/19 01:12 PM
Posts: 3,916 usa
lewtot184
usa
There has to be a lower bearing of some sort !! Not in the early floor shift columns. There might be something in the column shift setup. The floor shift column has a rubber and nylon type of seal arrangement at the bottom but not a bearing. Here are the two columns I'm working with. I need to convert my red column over to PS from manual steer so I'm parting out the blue column and putting the parts in my red column. that should be a simple swap. I had a piece made for the shaft to fit thru to fill that bottom column void. seemed it needed something.
[Re: dart4forte]
#2651224
05/02/19 01:23 PM
05/02/19 01:23 PM
Posts: 5,100 Western Md.
skicker
"The Champ"
"The Champ"
Western Md.
Yes... Andy what your doing is exactly how I did the one for my 65 Bel II... I had a 65 Column shift auto that came in my Bel II and bought a 64 floor shift column that had a bent p/s shaft... I used it installing a manual shaft from a 63 Dodge 3 on the tree car to make one for my 65... I've never seen any type of lower bearing and as you previously mentioned they are all solid shafts...
...FAFO...
[Re: skicker]
#2651231
05/02/19 01:48 PM
05/02/19 01:48 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
A simple look in the parts manual will show a bearing or lack thereof.
No need to guess.
[Re: lewtot184]
#2651299
05/02/19 05:32 PM
05/02/19 05:32 PM
Supercuda
About to go away
About to go away
up yours
A source would be nice, unless you make them yourself
[Re: Supercuda]
#2651323
05/02/19 06:45 PM
05/02/19 06:45 PM
dart4forte
Mesa, Arizona
A source would be nice, unless you make them yourself I’ve used an actual Timpken bearing
Abe Lincoln
