Re: Small Block Oil Pump Gasket
[Re: John_Kunkel]
#2652049
05/04/19 11:45 PM
05/04/19 11:45 PM
Posts: 4,457 Washington
madscientist
Washington
[quote=Kindafast] I've taken apart more than my fair share of engines that had never been touched and almost every one of them had a gasket. Never had a blowout. And yet I find no part number for a gasket and no mention of one in service manuals. Last mention of a gasket between the pump and cap was in the fifties and it was a lathe cut O ring. Don't know what to say. The first engine I pulled apart was mine. I was the second owner. First owner never touched it. It was an early 72 Demon. Has 2.02 valve and 10.5:1 Pistons. And it had a gasket under the pump. That was just the first one.
[Re: madscientist]
#2652284
05/05/19 02:48 PM
05/05/19 02:48 PM
Posts: 430 Washington
skrews
Washington
[quote=Kindafast] I've taken apart more than my fair share of engines that had never been touched and almost every one of them had a gasket. Never had a blowout. And yet I find no part number for a gasket and no mention of one in service manuals. Last mention of a gasket between the pump and cap was in the fifties and it was a lathe cut O ring. Don't know what to say. The first engine I pulled apart was mine. I was the second owner. First owner never touched it. It was an early 72 Demon. Has 2.02 valve and 10.5:1 Pistons. And it had a gasket under the pump. That was just the first one. I've pulled apart many untouched cores over the years and none of them had an oil pump gasket. 318s a few 340s and a bunch of 360s. Only time I find them is when the engine has been in to.
[Re: justinp61]
#2652560
05/06/19 11:29 AM
05/06/19 11:29 AM
madscientist
Washington
Guess I should have taken pictures.
[Re: skrews]
#2660209
05/29/19 02:54 AM
05/29/19 02:54 AM
Posts: 43,744 Bend,OR USA
Cab_Burge
Are you saying the goop built up around the front oil pump bolt on the pump and block and in the machine marks on both parts is not a gasket sealer or "sealing goop" of some type?
