Firm-Feel sway bar set-up #2649979
04/28/19 07:08 PM
04/28/19 07:08 PM
Houston, Tx
hemi68charger Offline OP
Houston, Tx
Mopar question;
Anyone have pictures of their Firm_feel sway bar set-up, in particular the supplies drag link bracket attached to the lower control arm for those cars that didn't come with one. The instruction sheet that they supply leaves a lot to be desired.. I'm working on a 70 Challenger.
Troy
Houston Mopar Connection Club
Re: Hotchkis sway bar set-up [Re: hemi68charger] #2650004
04/28/19 08:42 PM
04/28/19 08:42 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
why not just use a stock or PST unit?
Coming soon!!!!
Re: Hotchkis sway bar set-up [Re: Mr.Yuck] #2650037
04/28/19 10:34 PM
04/28/19 10:34 PM
Houston, Tx
Houston, Tx
Because my friend bought this kit and his car doesn't have a factory front sway bar, hence no perch bracket for the drag link bushings on the lower control arms.
Troy
Re: Hotchkis sway bar set-up [Re: hemi68charger] #2650422
04/30/19 05:54 AM
04/30/19 05:54 AM
Houston, Tx
Houston, Tx
The unit is a firm-feel, not hotchkis....
Troy
Re: Hotchkis sway bar set-up [Re: hemi68charger] #2650435
04/30/19 07:49 AM
04/30/19 07:49 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
I don't have any pictures but I put a firm-feel sway bar on my '65 coronet. the part I think your mentioning simply attaches at the lower shock mount bolt. very simple. the firm-feel sway bar on my '65 is far superior in road performance than the stock factory sway bar on my '69 coronet r/t. the only negative I can find with the firm-fell is it does impede wheel travel if your doing tight turns; as in parking the car.
Re: Hotchkis sway bar set-up [Re: hemi68charger] #2650565
04/30/19 03:06 PM
04/30/19 03:06 PM
MD
RTSE4ME Online content
RTSE4ME  Online Content
MD
Not sure I understand what the ask is but if the car did not have sway bar originally you need to weld the swaybar brackets on the LCA.
The brackets are not included with the sway bar. Sorry if I am misreading this.
Re: Hotchkis sway bar set-up [Re: lewtot184] #2651391
05/02/19 10:23 PM
05/02/19 10:23 PM
Albany, NY
67SATisfaction Offline
The member whose name is actually Art
Albany, NY
Same here - I installed a FirmFeel tubular front sway bar on our '65 Satellite. The two end link brackets bolted to my LCA through the bottom shock bolt. I did have to re-tighten the bolts after a hundred miles or so - I heard a funny squeak and the bolts needed tightening. I haven't noticed any interference with tight turns.
Cheers,
- Art
65 Satellite hardtop 361/4bbl console 727 2.76
67 Satellite convert 383/2bbl column 727 3.23
67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd
67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd
71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd
82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle
75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF
77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF
07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
