Re: Tranny fluid dilemma.
[Re: BlueRacer69]
#2649577
04/27/19 03:49 PM
04/27/19 03:49 PM
Posts: 25,743 Rio Linda, CA
John_Kunkel
Rio Linda, CA
With a stock pan, a pan gasket replacement usually requires 4 quarts depending on how long it sat after shutdown for a refill and, yes, you can mix fluids.
[Re: jvcuda]
#2649741
04/28/19 04:08 AM
04/28/19 04:08 AM
Posts: 20,626 in a cattle trailer down by th...
Guitar Jones
I disagree. I've never used type F in a non Ford trans. Just use Dexron, that is what it was designed to use. Type F was a bandaid for another Ford screwup. 4-5 quarts should be plenty.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: Guitar Jones]
#2649849
04/28/19 11:37 AM
04/28/19 11:37 AM
Posts: 4,951 northwest USA
NANKET
northwest USA
I disagree. I've never used type F in a non Ford trans. Just use Dexron, that is what it was designed to use. Type F was a bandaid for another Ford screwup. 4-5 quarts should be plenty. Agreed. Type F is among the worst for lubrication quality also. It’s not the hot ticket. If the fluid looks bad and pan has material inside then drain the converter and replace most of the fluid. Buy a case.
[Re: NANKET]
#2649904
04/28/19 02:18 PM
04/28/19 02:18 PM
John_Kunkel
Rio Linda, CA
I disagree. I've never used type F in a non Ford trans. Just use Dexron, that is what it was designed to use. Type F was a bandaid for another Ford screwup. 4-5 quarts should be plenty. Agreed. Type F is among the worst for lubrication quality also. So, Ford transmissions are failing left and right from lack of lubrication? My anecdotal experience says otherwise.
[Re: BlueRacer69]
#2649907
04/28/19 02:24 PM
04/28/19 02:24 PM
Posts: 15,823 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Valvoline Dex/Merc is not synthetic. Type F supposedly will give firmer shifts so if that's what you want in lieu of better protection I guess.
I don't understand why this is a recurring controversy, but then I'm no expert.
Facts are stubborn things.
[Re: John_Kunkel]
#2649920
04/28/19 02:55 PM
04/28/19 02:55 PM
Posts: 8,667 Buford, GA
I_bleed_MOPAR
Buford, GA
I disagree. I've never used type F in a non Ford trans. Just use Dexron, that is what it was designed to use. Type F was a bandaid for another Ford screwup. 4-5 quarts should be plenty. Agreed. Type F is among the worst for lubrication quality also. So, Ford transmissions are failing left and right from lack of lubrication? My anecdotal experience says otherwise. with John. I've run Type F for years in 727s. Even ran the B&M TrickShift fluid but stopped buying it after I met a gentleman who worked for B&M that told me not to waste my money on TrickShift fluid. Said it was only Type F with a couple of additives and a color change, and regular Type F worked just as well. When I got the Charger back on the road, I went on the race board and asked about fluid since I had been out of the hot rod game for 20 yrs. or so. Most everyone recommended Type F from Walmart. Been in it ever since with no problems. Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
[Re: John_Kunkel]
#2649957
04/28/19 05:07 PM
04/28/19 05:07 PM
Guitar Jones
I disagree. I've never used type F in a non Ford trans. Just use Dexron, that is what it was designed to use. Type F was a bandaid for another Ford screwup. 4-5 quarts should be plenty. Agreed. Type F is among the worst for lubrication quality also. So, Ford transmissions are failing left and right from lack of lubrication? My anecdotal experience says otherwise. No they aren't but, put Dexron in a Ford transmission that requires type F and see what happens.
[Re: John_Kunkel]
#2650120
04/29/19 09:23 AM
04/29/19 09:23 AM
I_bleed_MOPAR
Buford, GA
With a stock pan, a pan gasket replacement usually requires 4 quarts depending on how long it sat after shutdown for a refill and, yes, you can mix fluids . Personally, I would drain the converter also and adjust the bands, especially if it hasn't been serviced in the 20+ yrs. you have owned it. Tim
[Re: DaveRS23]
#2650168
04/29/19 11:09 AM
04/29/19 11:09 AM
Posts: 19,336 north of coder
moparx
this is somewhat relevant, in that it applies to non-recommended fluid, but i have ran, and continue to run, dexron in my 4spd front drive minivans for 100's of thousands of miles with absolutely NO problems what so ever. 95 minivan - over 318k+ [speedometer broke], 2000 minivan - 240k, 99 minivan - 168k, my wife's 94 chrysler concorde - 138k. but we don't do dragstrip duty either. your results may vary i wouldn't sweat ford fluid in a 727, no matter the brand chosen.
[Re: Guitar Jones]
#2650206
04/29/19 01:01 PM
04/29/19 01:01 PM
John_Kunkel
Rio Linda, CA
Don't keep us in suspense.
