Firm-Feel sway bar set-up
#2649979
04/28/19 07:08 PM
04/28/19 07:08 PM
Posts: 8,827 Houston, Tx
hemi68charger
Houston, Tx
Mopar question; Anyone have pictures of their Firm_feel sway bar set-up, in particular the supplies drag link bracket attached to the lower control arm for those cars that didn't come with one. The instruction sheet that they supply leaves a lot to be desired.. I'm working on a 70 Challenger.
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
Re: Hotchkis sway bar set-up
[Re: Mr.Yuck]
#2650037
04/28/19 10:34 PM
04/28/19 10:34 PM
hemi68charger
Houston, Tx
why not just use a stock or PST unit? Because my friend bought this kit and his car doesn't have a factory front sway bar, hence no perch bracket for the drag link bushings on the lower control arms.
[Re: lewtot184]
#2651391
05/02/19 10:23 PM
05/02/19 10:23 PM
Posts: 7,538 Albany, NY
67SATisfaction
The member whose name is actually Art
Albany, NY
I don't have any pictures but I put a firm-feel sway bar on my '65 coronet. the part I think your mentioning simply attaches at the lower shock mount bolt. very simple. the firm-feel sway bar on my '65 is far superior in road performance than the stock factory sway bar on my '69 coronet r/t. the only negative I can find with the firm-fell is it does impede wheel travel if your doing tight turns; as in parking the car. Same here - I installed a FirmFeel tubular front sway bar on our '65 Satellite. The two end link brackets bolted to my LCA through the bottom shock bolt. I did have to re-tighten the bolts after a hundred miles or so - I heard a funny squeak and the bolts needed tightening. I haven't noticed any interference with tight turns. Cheers, - Art
65 Satellite hardtop 361/4bbl console 727 2.76 67 Satellite convert 383/2bbl column 727 3.23 67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd 67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd 71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd 82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle 75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF 77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF 07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
